06-14-2006, 13:41 | #1 (permalink) |
Major Poster Join Date: Jul 2005 Location: Germany Age: 43
Member: 159036 Status: Offline Thanks Meter: 4 | Cable for LG KG800 make easy 2.Take any standart data COM cable (RX,TX,GND) 3 Use original USB cable. 4. Engoy vygis software... |
The Following 2 Users Say Thank You to AndyFox For This Useful Post: |
06-14-2006, 14:00 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | Sorry guys,but this wont work.KG800 uses new small 18 pins connector,and unlocking-flashing is possible only via UART,so USB cable can't be used for this.Exist only one way to make own cable by cutting this 18 pins connector from USB cable or from handsfree and soldering it to the cable with RJ45 on the other end.Or other way-wait until tele-way will make this new cable,as seems all newer LG will be using this new small 18 pins connector-at this moment KG320 also uses it. |
06-14-2006, 14:10 | #4 (permalink) | |
Member: 159036 Status: Offline Thanks Meter: 4 | Quote:
06-14-2006, 14:11 | #5 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
does the cable of SAMSUNG 18pins are the same with KG800 and the pin location are different? br RNC_EBM | |
06-14-2006, 15:21 | #7 (permalink) |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Well , The Solution Is Working !!! Only Thing He Cant Explain Properly.... The Details Are..... U Need.... 1--- Usb Cable Original Comes From Box Pack. 2- A Female Connector For Usb ( Same As Ufs - Hub Connector -eg Only) 3-- A Normall Rx Tx Gnd Com Port Cable . Cut It And Made Wires Open. Now Use The Diagram In First Post , Solder Those Wires( Rx, Tx And Gnd) On Female Usb Connector ( Eg, Like Ufs Hub Connector) Now Attach Ur Usb Main Orignal Cable Comes In Box To This Female Connector . So Now U Have The Cable Ready To Unlock. So End Of Cable Is The Comport And Other End Goes In Fone , And In Between Is The Connection Of Usb Male And Female Connector!! Enjoy Br, Gohar Abbas Fones Clinic Ltd. Last edited by F C; 06-14-2006 at 15:32. |
The Following User Says Thank You to F C For This Useful Post: |
06-14-2006, 15:25 | #8 (permalink) | |
06-14-2006, 15:37 | #10 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Voda & 3 UK DIRECT Source
Member: 78936 Status: Offline Sonork: 100.1575790 Thanks Meter: 426 | Quote:
always try to help the members good work br hafiz | |
06-14-2006, 18:52 | #11 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | Oh,I must say sorry for AndyFox,as not understood your idea before,anyway seems that your solution must work It must work for unlocking-flashing,but for working with service commands-phone reset,read-write imei is needed normal cable based on pinout from support. Regards,Vygis |
06-23-2006, 08:49 | #12 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 298814 Status: Offline Thanks Meter: 0 | Quote:
This will damage the phone. Because the Com 's voltage is +/-12v,and the USB's voltage just +5v. And it need an RS-232 line driver/receiver chip. | |
06-23-2006, 12:38 | #13 (permalink) | |
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Quote:
WELL, JUST ANSWER ME ONE SIMPLE THING , DID U TRIED WHAT IS WRITTEN , AND DID IT DAMAGED THE FONE ? and i think u use your original nick to post here br. GOHAR ABBAS. | |
i-Pmart BX Series RJ45 Cable For LG KG800 For ET Box / Infinity Box / Vygis Box / Blu | IPMART | ipmart WebShop | 0 | 05-14-2009 16:00 |
Compatible USB Cable For LG KG800 / KG320 / KG245 / KF240 / KF300 | IPMART | ipmart WebShop | 0 | 04-30-2009 14:40 |
i-Pmart BX Series RJ45 Cable Compatible For LG KG800 For Infinity Box | IPMART | ipmart WebShop | 0 | 03-14-2009 07:50 |
Need Help: which cable for LG KG800 | elgar | n-Box | 0 | 05-12-2007 00:34 |
Which cable for LG KG800 ? | Munchie | LG | 6 | 04-17-2007 14:41 |
