Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > FuriouS TeaM Products
FuriouS TeaM Products FuriouS GOLD Support Area
Old 06-26-2006, 11:17   #1
GSM MIND
Moderator
GSM MIND's Avatar
Member: 20645
Sonork: 100.1579175
Emblaze Always Error Of Unlocking
hi mates and prdocut supports
i have problem to unlock my embaze phone when ever i try to unlock always got error change buad rate i did but same error i download the new version with this hope that some bugs are fixed in this version but still have same problem......
Press power on !
Starting communication ...
Trying baud rate change ...
Error ... !
Time needed - 00:00:01
any help or tip need urgent
REGARDS
GSM MIND
Old 06-26-2006, 14:16   #2
FuriouS TeaM
FuriouS TeaM's Avatar
Member: 4584
Cable problem. Please try another cable.
BR.
Steve.
Old 06-26-2006, 14:22   #3
GSM MIND
Moderator
GSM MIND's Avatar
Member: 20645
Sonork: 100.1579175
BR.
Steve.
can u post here the pinout or picture from where to modife my cable
if yes thanx in advance
REGARDS
GSM MIND
Old 06-26-2006, 17:09   #4
FuriouS TeaM
Member: 4584
i don't have pinout right now on my hand but im sure if you do a small search on forum u can find it easy cause we already posted here.
Also soon new list with all pinouts of cables will be ready on support area and many pdf file with tutorials.
BR.
Steve.
Old 06-26-2006, 18:12   #5
.:hack3r2k:.
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
REGARDS
GSM MIND
To be more specific your problem is caused by the fact +5V are not enabled !!! So use left rj45 from box, switch up and enable +5V (press red button behind box).
Old 07-20-2006, 16:16   #6
aarthy
Member: 95807
some one help emblaze error
Press power on !
Error ... !
Old 07-20-2006, 19:26   #7
.:hack3r2k:.
Member: 15022
Sonork: 100.53452
Press power on !
Error ... !
You need +5v enabled ! Use left rj45.
Old 07-21-2006, 09:24   #8
aarthy
Member: 95807
i make acable pinouts with furious team theay has given
but still same error
any body help me pleas
Old 07-21-2006, 14:27   #9
.:hack3r2k:.
Member: 15022
Sonork: 100.53452
You made the cable bad. If not +5v then u have same error u posted !
Old 12-20-2006, 20:07   #10
wardak
wardak's Avatar
Member: 64672
here is the points !
connector 18-pin
you can use the samsung A300 connector
keyboard top
1..............18
1:Gnd
9hone Tx (connect to +5v via 1ok resistor)
10hone Rx (connect to +5v via 1ok resistor)
best regards
Page generated in 0.08795 seconds with 6 queries
