Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Infinity-Box
Old 07-03-2006, 12:35   #1
ASHIF
ASHIF's Avatar
Member: 8353
Sonork: 113276
unsupported C168 version
COM3 selected
Device: C168
Checking data, wait...
Action: Unlock
Boot...
Phone should be Switched OFF !
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
SW ver: 1420-000
HW ver: TCT-9-
Check Flash Done
Check Parameters...
Err: this version is not supported yet. read flash and send to support
Check Parameters Fail
Finished
Remove/Install battery now !
Time used: 12 sec
Make "SP-Unlock" operation now !
Should i flash this phone first with another version or wait for update?????
Old 07-03-2006, 12:53   #2
ASHIF
ASHIF's Avatar
Member: 8353
Sonork: 113276
i flashed it with other flash file now......mobile is unlocked by moto02-v111 but it say "NETWORK PIN BLOCKED".............
Old 07-03-2006, 23:30   #3
InfinitySupport
Member: 130995
it was not so good idea to flash phone because version that was in your phone mewer that we have in support.
Please, if you will see phone with this version (1420) in future read flash and send to InfinityHelp@yahoo.com.hk and we will make update fast.
As about blocked "network pin". pls, send me all backup files that was auto-created after unlock: InfinityHelp@yahoo.com.hk
Also it can be that it's need to power on phone and wait some time untill it will be possible to enter network pin.
Old 07-04-2006, 10:11   #4
ASHIF
ASHIF's Avatar
Member: 8353
Sonork: 113276
my problem solved by flashing fone with firmware present in support....and yes after 2 hours "network pin blocked" message gone....and i unlocked fone by codes easily....
i have mailed the backup file on that address
Old 07-04-2006, 15:15   #5
InfinitySupport
Member: 130995
Hello,
Glad to hear about good results.
Thanks for backup file. Update for this software version will be uploaded in support area today in some time.
Old 07-04-2006, 21:59   #6
damabib
damabib's Avatar
Member: 106026
Sonork: 100.77890
nice suopports infinity is really frindly and supports
Old 10-09-2006, 16:40   #7
irfanamin2
irfanamin2's Avatar
Member: 82423
i mail you support team "nfinityHelp@yahoo.com.hk" I try all version but still same problem "Network Pin Blocked" pleses solve my problem.
Old 10-09-2006, 17:28   #8
InfinitySupport
Member: 130995
must read previous post in this thread:
Old 10-25-2007, 21:11   #9
sharmin
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
so whats the perfect procedure to prevent the messege network pin blocked ...
Old 10-25-2007, 23:04   #10
InfinityHelp
Member: 148515
hello!
just press "repair" if you face this problem
Old 01-24-2009, 23:20   #11
tysonx
Member: 565786
which cable do u guys use to connect the c168 abd can u direct me on how to unlock mine i have a at&t c168i
Old 01-25-2009, 03:13   #12
InfinitySupport
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http://forum.gsmhosting.com/vbb/showthread.php?t=342807
Old 02-02-2009, 06:08   #13
eck4u2002
Member: 350153
i have alcatel s320x and dont have the cable how can i make my own cable?
Old 02-02-2009, 14:42   #14
InfinitySupport
Member: 130995
Hello,
Page generated in 0.09264 seconds with 6 queries
