Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Infinity-Box
Old 07-04-2006, 14:42   #1
Sezamek
Member: 144165
C261 - problem with connecting
I can`t this understand. I have C115 and I connect the phone without any problem , but C261 not( but can user code reset and then I can connect the phone) So, I can connect only when I want to reset user code , but flashing not (i have press ON
I use the same cable . It is a different cable for C261 ?
Action: Flash
Write: Firmware
Write: Flex
Write: Language Pack
Device: C261
Checking data, wait...
Connect...
Press and HOLD Power button...
and nothing happend
but when i try to reset user code i have
COM1 selected
Device must be POWERED-ON !
Connecting, wait...
Device connected. Working...
Current Imei: 359197000174848
SW Version: 0166 MOTOROLA_E58S
User Code reset Ok
?????????????????????????????? Could anybody me explain this?
Old 07-04-2006, 14:45   #2
Sezamek
Member: 144165
re: Motorla C261
I try to connect 2 x C261 and problem not solved , so i can`t flashing but user code wihtout problem
Old 07-04-2006, 15:11   #3
InfinitySupport
Member: 130995
Use latest Moto01_V120 from support area "Updates" section.
Old 07-07-2006, 23:31   #4
lutech
Member: 35102
Mr Infinity, I try unlock c 261, with sw 1.20. But have answer- connection fail , or incorrect certificate.Cable is ok. How solved it?
Old 07-09-2006, 11:39   #5
InfinityHelp
Member: 148515
change sertificate1 or sertificate 2 in settings
it is in default position now.
please make back up before trying
Old 07-09-2006, 18:34   #6
lutech
Member: 35102
,, this unit can,t be unlocked,, .Wehn?
Old 07-09-2006, 21:57   #7
InfinitySupport
Member: 130995
to lutech: to be honest I did not understand your question.
make this:
1. Download Moto01_v120 from support area
2. in Settings tab select "Sertificate-1" or "Sertificate-2" instead of "default"
3. make full flash backup
4. try to make unlock
Old 07-10-2006, 22:29   #8
hs.com
hs.com's Avatar
Member: 200653
Moto c261 no net problem ? Plz Help Me With Thanks
Old 07-11-2006, 09:01   #9
green bird
green bird's Avatar
Member: 109163
IF you have X60 cable, thats work fine. T191 cable getting error.
Page generated in 0.09504 seconds with 6 queries
