Member: 125366 Status: Offline Thanks: 29
Motorola 168 After Flash DEAD
Today i recived moto 168 in phone code , then i unlock show code 1820 when i inter code show (incroct code) . then i flash to try show this ....
COM6 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1180-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 try to recovery erase error [43] try to recovery erase error [5D] try to recovery write error [00:45:00000000] Writing Fail Finished Remove/Install battery now ! Time used: 30 sec moto is dead i also Read backup But How we can write Backup file ? |
Member: 130995 Status: Offline Thanks: 4,377
Download latest Moto02 v1.14 from support area and try again. Also for info: flashing main+lp+flex+images+melody dont have any effects for removing phone code. |
COM5 selected
Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 Err: error flash command try to recover erase error#43 (Same Condition) |
Sir i read backup .But How we can write backup my Dead moto 168 pleaz Help me ?
it's not a problem with backup or wrong firmware or something like this. The problem is: flash can't be written. I don't know the reason for sure but my advice: open phone, check flash chip. maybe water, maybe need to rehot it. Of course it can be something else but can't imagine right now what it can be. It's really strange that readed phone code was wrong. also very strange that phone can't be flashed so I think there is a reason to check hardware. |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006
Member: 235881 Status: Online Thanks: 23
plz help
i have the some problem i don't know what i can do plz this is flash procedure
COM5 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 203125 Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF try to recovery write error [00:54:00000000] try to recovery write error [01:5D:00000000] Err: no any answer Writing Fail Finished Remove/Install battery now ! Time used: 39 sec !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
![]() ![]() ![]() ![]() ![]() Join Date: May 2002
Member: 12296 Status: Offline Thanks: 2
Try to reflow the flash and use fully charge battery..
WBR Surej |
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002
Member: 8426 Status: Online Thanks: 5
nothing to reflow or to rehot .....
exacltly same problem here
battery was full charged phone 100% was ok now phone dead in prepare Writing... Write: Firmware Flash: 0089:886400010001 Err: error flash command try to recover erase error#43 pls need fix that problem as soon as possible best regards
Member: 39069 Status: Offline Thanks: 41
If all here after flash phone dead please try to flash deferent version.Here I use version _1280_ all files (main, flex, lp, mel and amage the same _1280_)
Loading file [version 02]... C168_Main_7-1280-000_2006-Feb-22.69M.bin Loaded Loading file [version 02]... C168_Flex_1280-007_T676FC_8V33_V1.69F.bin Loaded Loading file [version 02]... C168_LP_1280-005_T676FB_8V33_V1_En_Cn_Ml.69P.bin Loaded Loading file [version 02]... C168_Melody_1280-004_T676EW_8V33_V1.69G.bin Loaded Loading file [version 02]... C168_Images_1280-004_T676EW_8V33_V1.69G.bin Loaded |
Hi to all,
C168 flashing will be double checked ASAP ! |
![]() ![]() ![]() ![]() Join Date: Dec 2003
Member: 46116 Status: Offline Thanks: 26
Iam also having the same problem Pls help me too....
Here is my log COM1 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Err: error flash command try#1 to recover erase error#43 Err: error try#00 to recover write error at 00000000 Writing Fail Finished Remove/Install battery now ! Time used: 129 sec Actually aim posting this for third time pls help me to recover my phones, I have two phones same error.... |
Please, send me full log file to InfinityHelp@yahoo.com.hk
![]() ![]() Join Date: Jul 2006
Member: 303845 Status: Offline Thanks: 0
plz flash with the version of 1490 main+flex+lp+image +tones the problem will be solved
i had solved the problem of pack error with the help of these files
