Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Motorola > Motorola Hardware Repair Section
Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing.
Old 07-12-2006, 14:08   #1
fanbang
fanbang's Avatar
Member: 73674
V300 & V525
3 problem phones:
1) v300 when power on. after display hellomoto then goes to white screen. then it just blinking white screen every few seconds. already done PDS repair and full flash with smart clip twice.
2) v525 no service. already flash it to v525m. still same. phone is not barred.
3) V525 not charging. someone please show me where the charging fuse is. did search but can't find it.
thanks
br
Old 07-13-2006, 22:50   #2
popzoran
popzoran's Avatar
Member: 91406
For 525 charging............
Old 07-14-2006, 00:32   #3
fanbang
fanbang's Avatar
Member: 73674
thanks for replying. is it this 1 circled in red?
br
Old 07-15-2006, 05:44   #4
agent_lia
Member: 291404
many thanks for the info and more power
Old 07-15-2006, 14:46   #5
fanbang
fanbang's Avatar
Member: 73674
replaced component. not worked. still no charging. any other solutions please?
thanks
br
Old 07-17-2006, 22:22   #6
popzoran
popzoran's Avatar
Member: 91406
Try this one
http://forum.gsmhosting.com/vbb/showth...=v500+charging
Old 07-19-2006, 17:29   #7
fanbang
fanbang's Avatar
Member: 73674
@popzran. thank you. working now.
btw. got solution for E1 "unable to charge"
pins and battery are ok.
thanks
br
Old 07-19-2006, 19:25   #8
car__34
Member: 76729
FANBANG For the V300 Try Reflowing the PA (U50) in the service manual... that will be the last hope you could have...
Old 07-19-2006, 19:26   #9
nik789
nik789's Avatar
Member: 278535
thanks all for that information keep it up
Old 07-20-2006, 15:21   #10
fanbang
fanbang's Avatar
Member: 73674
after Reflowing the PA (U50). now i have no display at all.
Old 08-17-2006, 09:26   #11
ipsylon
Member: 265149
You have no display after rehoting PA or phone doesn't want to turn on? If the second option then maybe you probably have a shortcut under the PA. Try to rehot it again. If you have problem with display and battery doesn't wanna to be charged then probably it's U900 PCAP problem.
Old 09-30-2006, 09:53   #12
mujie
mujie's Avatar
Member: 8304
aRE YOU A SICK ANIMAL OR WHAT???????????..........What does P.A have to do with charging?????????
Old 09-30-2006, 09:55   #13
mujie
mujie's Avatar
Member: 8304
Now thats what you get for being a Dumb-a$$
Old 10-01-2006, 20:39   #14
fanbang
fanbang's Avatar
Member: 73674
ok you clever D**k from mars r u on drugs or something
1st. the v300's problem is display. not charging. if u read post properly.
2nd. have u got a working solution?
3rd. if u just come on here to slag people off rather then here to help, then I suggest to go get pi$$ed or somthing........
br
Old 02-02-2007, 10:58   #15
sweix
Member: 256978
Try this sheme, mybe helps. My works this solution.
Page generated in 0.10206 seconds with 7 queries
