Member: 308951 Status: Offline Thanks: 0
Toshiba Stack V4.20.1
All
I have tested Broadcomm versions 4 thru to 5.1.0.1700 on MS, Belkin, Logitech and CSR dongles. I have also tested Toshiba V4.00.31 on all these. Toshiba stack is by far the most stable on ALL of these dongles. My mouse and KB (Logitecg & MS) connect flawlessly everytime on computer start, my stereo bluetooth headset (Moto HT820) connects and the performance is superb. No static, drops or hisses. When I pause and resume, I always get the music. AVRCP profile works even after a pause of 30 mins. I was having problems with V5xxxx of Broadcomm stack with my above devices. My suggestion is to go for the Toshiba stack. There is a V4.20.1 available on: http://aps.toshiba-tro.de/bluetooth/pages/download.php I have not tested this yet, but V4.00.36 had copy protection for stereo Bluetooth devices (it will only pair to devices that conform to SCMS-T copy protection method). As for V4.00.31 I have this, but in order to be useful you will have to modify the btwusb.inf equivalent file called tosrfusb.inf with yor devices VID and PID. I am willing to upload V4.00.31 (32 bit only) to a common site; someone will have to tell me where and how. |
![]() ![]() Join Date: Jan 2006
Member: 223748 Status: Offline Thanks: 0
thanks for the hint. Anyway, I already tried the Toshiba BT stack in the past and also noticed that it is very stable. Unfortunately, either past and actual versions are all limited to a 30 days trial and I could not find any solution so far. If only somebody could help there Regards, ulysse |
![]() ![]() Join Date: Apr 2006
Member: 265040 Status: Offline Thanks: 0
see about
refered from: http://www.moshoo.com/bbs/read.php?tid-140-fpage-3.html the article is written in Chinese, But the attachment is worked in multilanguage. the attachment is worked for time-limit. and the following is the killer for SCMS-T copy protection: (import to the registry) Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Toshiba\BluetoothStack \V1.0\AV] "NoHeader"=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\Toshiba\BluetoothStack \V1.0\EZC] "ShowAvContentProtectionMenu"=dword:00000001 err, the attachment exceed the limit of uploading. u can dl from here: http://www.moshoo.com/bbs/job.php?ac...0-aid-283.html. good luck. PS:the attachment is tested in 4.00.30&4.00.36 Last edited by lidouf; 07-31-2006 at 07:48. |
Thanks lidouf, but unfortunately your solution does not help
I found a similar file that does not help neither (not sure what it is good for so) : Code:
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack] "UseResourceType"=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack\V1.0\AV] "NoHeader"=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack\V1.0\EZC] "ShowSelectAVPlayerMenu"=dword:00000001 "OEMType"=dword:00000001 "ShowAvContentProtectionMenu"=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack\V1.0\EZC\SupportService] [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack\V1.0\EZC\SupportService\000000] [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack\V1.0\EZC\SupportService\000100] [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack\V1.0\EZC\SupportService\000200] [HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\BluetoothStack\V1.0\Mng] "RightMenuType"=dword:00000002 [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\AFH] "WirelessLAN_Channel"=dword:00000000 "CurrentChMap"=hex:00,00,00,00,00,00,00,00,00,00 [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\AV] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\AV\A2DP] "BdAddr"=hex:00,00,00,00,00,00 "EnableCheckSCMS_T"=dword:00000000 [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\AV\AVRCP] "BdAddr"=hex:00,00,00,00,00,00 "DAPriority"=dword:00000000 "Drive"="" [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\EZC\DATA] "NextID"=dword:000003eb [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\HS] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\HS\HSP] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\HS\HSP\Cmdvalue] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\Mng] "LastInquiryTime"=hex:fa,8c,72,5a,1b,38,c5,01 [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\Mng\AutoConnectCOMM] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\Mng\DeviceProperty] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\OBEX] "DisableStandby"=dword:00000001 [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\SDDB] "UniqueNum"=dword:00000046 "TimeStamp"=hex:d0,3c,c7,06,8a,38,c5,01 "LocDevRecHandle"=dword:00010109 "ServiceDatabaseState"=dword:0000015a [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\TosBtExt] "Display Settings"=hex:64,00,00,00,64,00,00,00,01,00,00,00,00,00,00,00,64,00,\ 00,00 [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\TosBtExt\Addin] [HKEY_CURRENT_USER\Software\TOSHIBA\BluetoothStack\V1.0\TosBtExt\Folder] |
u means the SCMS-T protection or the time-limit?
I tried it, It's ok. [HKEY_LOCAL_MACHINE\SOFTWARE\Toshiba\BluetoothStack \V1.0\AV] "NoHeader"=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\Toshiba\BluetoothStack \V1.0\EZC] "ShowAvContentProtectionMenu"=dword:00000001 err, something wrong with the system.. the space after the word "BluetoothStack" should be deleted, the attachment is the file exported from my registry. And import it to the registry or add it into manually. Last edited by lidouf; 07-31-2006 at 08:00. |
I mean the time limit (don't even know what SCMS-T protection is)
By the way, I already corrected the errors in your pasted code an now tried with your reg patch, but the time limit is still active
u can try with this patched file to overwrite the same file in the directory(backup first) and then I shoul only say good luck, for mine is ok. I can't sure it's ok for all bt dongles.
Thanks a lot, lidouf
Your patched file seems to work Did you patch it yourself, how did you do? What did you change in the file, time limit only or also SCMS-T (by the way, what is SCMS-T) ? Thanks, ulysse |
this patch was made 2~3 months ago, based on v4.00.30, but it worked for the current version. I can't guarrantee It can work fine for all functions of the newer version. So , good luck.
![]() SCMS-T is a copyright protection method of bluetooth. u see, I don't understand more things. for example, without this protection, mp3 or other music files can spread to others through bluetooth link, So the copyright of these musics can't be protected, so...(anyone knows the exact answer plz post it up) time limit patch only made the change that the bt stack can capable with all bt devices(uncertified bt devices have no time limit) |
#10 | |
I think SCMS-T's function is mainly about protecting the contents transferring with bt link.
time protection is for the bt stack software, only certified bt devices can use the toshiba bluetooth stack software freely. |
