Old 09-16-2006, 19:12   #1
Khatulistiwa
Khatulistiwa's Avatar
Member: 209644
Java (J2ME) Application Only !!!!!!!
Hi All....
I will upload here java application for the mobile phones s 60 etc...
if u like please post here free java application to download.
Old 09-16-2006, 19:19   #2
Khatulistiwa
Member: 209644
kurvNet.BlueIM.v1.01.S60.J2Me
The BlueIM application is an Instant Messaging application which runs over Bluetooth.
The application is designed to run on mobile devices (phones, PDAs etc) which support Java 2 Micro Edition (with MIDP 2.0 and CLDC 1.1). In order to run the application your device must also have Bluetooth and support the JSR-82 Java API for Bluetooth (check with your device vendor if you are unsure).
Old 09-16-2006, 19:22   #3
Khatulistiwa
Member: 209644
TalkTimer v1.00 Full Free java by Daniel Lindholm
TalkTimer v1.00
This is a stopwatch application with BIG NUMBERS. The numbers will adapt to the size of the display in your phone or PDA.
I made this because I had problems reading the digits in the build-in stopwatch in my Sony-Ericsson telephone from a distance.
If you enter a time limit with the numeric keys, the timer will give a sound signal when the time limit has been reached.
Switch between setting time limit in minutes or seconds with the * key.
Old 09-16-2006, 19:25   #4
Khatulistiwa
Member: 209644
BMDConcerto v1.1 Full Free Java
BMDConcerto v1.1
MIDI Player for Java MIDP 2.0 Compatible phones. Plays continuous. You can use it if your phone doesn’t have a radio or MP3 player or if your phone memory isn’t large enough. Options: play/stop/pause/prev/next. It also displays the phone`s time, so you don`t have to close the application to see the current time. Tested on Sony Ericsson K700i and works just fine.
Old 09-16-2006, 19:28   #5
Khatulistiwa
Member: 209644
World Clock v0.2.23 full free java
World Clock v0.2.23
World Clock is an application that tells you the time in different parts of the world. It will automatically calculate the day light saving and apply it where necessary.
It includes 4 different themes, 24/12 hour displays and saves your current location and preferences.
Old 09-16-2006, 19:30   #6
Khatulistiwa
Member: 209644
Tevero.Stopwatch V1.0 java freeware
Supports up to 5 simultaneous stop******* each with up to 40 split/lap times and average lap time. Persistent settings for time and split/lap times. Allows stopwatch to continue to run even when exiting Java application. Simple and efficient user interface, no fancy graphics. Embedded "user manual". For more details see: w*w.tevero.no/espace/stopwatch,especially for comments on issues that may affect accuracy of a Java stopwatch utility. Picture shows use on Nokia E70. Look will vary with device type. Both split/lap times only shown at same time if screen can fit both. Free use, as is.
Features :
*Up to 5 individual stop******* each with up to 40 cumulative split and lap times.
*Stopwatch up to max 999 hours 59 minutes 59.99 seconds with 1/100 of a second accuracy. You may argue; what is the point with an accuracy of 1/100 of a second when measuring 100s of hours? And my answer is laziness, I didn't bother to strip away those decimals for you with the impact it may have on layout/alignment. Accuracy admittedly also depends on the system timer of the device, which has not been tested on any device. And it depends on system latency when pressing a button. Design considerations have been given to ensure minimum delay from pressing button until stopwatch is started/stopped etc., but you never know what is going on in there. Don't worry too much, it seems to do the job.
*Persistent saving of data for all stopwatch instances (but nothing saved for a stopwatch instance in reset state, which probably is the most common thing).
*Simple key interface with what I believe is convenient use of the keys for fast and accurate use. Based on assumption that most common use is start/stop/reset. Can be used with joystick/soft buttons and/or numeric keypad.
*Stopwatch will "keep" running even if closing the Java application when running. Saves battery if required to run the stopwatch for a long time.
*Designed with low CPU/power usage in mind. That is, update to display (which is the main CPU intensive activity) is only done as required by state of shown stopwatch instance.
File Type: zip Tevero.Stopwatch V1.0 java freeware.zip (54.9 KB, 223 views)
Old 09-16-2006, 19:40   #7
Khatulistiwa
Member: 209644
Mobile Gmaps.v1.28.02.S60&S80.freeware
Mobile GMaps is a FREE application that displays Google Maps, Yahoo! Maps, Windows Live Local (MSN Virtual Earth) and Ask.com Maps and satellite imagery on Symbian and Java J2ME-enabled mobile phones, PDAs and other devices. MGMaps can connect to a GPS receiver over bluetooth or use internal GPS features on some phones in order to automatically display the map for your current position.
GPS connectivity: connect to a GPS device over bluetooth or use the internal GPS to view maps or aerial imagery for your current location. Enable GPS synchronization to continuously move the map as you move around, view your position, speed and heading.
Maps and satellite imagery: view various types of maps and aerial images, zoom in and out, mark favorite places with map pushpins.
Search for places or businesses, view the results including addresses and phone numbers. Do you want to call any of them? You can do that directly from Mobile GMaps!
Bookmarks: store your favorite places or search results to jump quickly to any of them.
Mobile WikiMapia:New! WikiMapia.org is a mashup that allows users to add tags and annotate locations displayed on Google Maps. They already have over 1 million places, now you can view them on your cellphone using MGMaps!
View KML files:New! view any .kml file available online containing Google Earth places by simply entering its web address. Compressed files (.kmz) are also supported.
Subway maps: view subway maps for New York, London, Berlin, Washington DC, Boston.
Connectivity with Navizon: use MGMaps together with Navizon in order to support GPS functionality over bluetooth on older Symbian S60 phones and to enable positioning features without a GPS device.
See w*w.mgmaps.com for more details.
Compatible Devices :
BenQ P30, BenQ P31, Motorola A1000, Motorola A920, Motorola A925, Nokia 3230, Nokia 3250, Nokia 3600, Nokia 3620, Nokia 3650, Nokia 3660, Nokia 5500, Nokia 6260, Nokia 6600, Nokia 6620, Nokia 6630, Nokia 6670, Nokia 6680, Nokia 6681, Nokia 6708, Nokia 7610, Nokia 7650, Nokia 7710, Nokia 9200 Series Communicator, Nokia 9210 Communicator, Nokia 9290 Communicator, Nokia 9300, Nokia 9500, Nokia E50, Nokia E60, Nokia E61, Nokia E62, Nokia E70, Nokia N-Gage, Nokia N-Gage QD, Nokia N70, Nokia N71, Nokia N72, Nokia N73, Nokia N80, Nokia N90, Nokia N91, Nokia N92, Nokia N93, Panasonic X700, Panasonic X800, SendoX, Siemens SX1, Sony Ericsson P800, Sony Ericsson P900, Sony Ericsson P910, Sony Ericsson P990.
File Type: zip Mobile Gmaps.v1.28.02.S60 S80.freeware.zip (90.0 KB, 527 views)
Old 09-16-2006, 19:44   #8
Khatulistiwa
Member: 209644
Bluetooth Messenger V1.2.9 freeware
This network will allow users to transfer text messages via bluetooth connections in short distances. You can have more than 1 clients for messages you send.
First of all, searching for active devices on which this service is running, is needed. All devices will be added to your clients and you can control their access mode in settings menu.
You can choose which devices have the authority to receive your messages and which have not. As default no device would receive your messages. So choose trusted devices from settings menu.
"messages" will lead you to send and receive enviornment. You can send messages in unicode format.
Old 09-16-2006, 19:48   #9
Khatulistiwa
Member: 209644
Quran juz30 v1.0 java (Indonesian) freeware
Quran juz30 v1.0 (Indonesian)
Islamic Java Application The Translation of Quran Juz 30 in Bahasa Indonesia(Indonesian) We hope this application could become a reference for the moslems (especially in Indonesia) .
File Type: zip Quran juz30 v1.0 Indonesian freeware.zip (26.5 KB, 239 views)
Old 09-16-2006, 19:50   #10
Khatulistiwa
Member: 209644
SecretCodes v1.4.1 full free java
SecretCodes v1.4.1
Secret Codes is a simple program which is able to store all your secret codes in the phone memory cyphering with one password. It synchs with PC. I tested on Motorola E1070. It is opens source software. This program is given WITHOUT warranty. The inital screen shows all the available databases plus the options help and about. Select a database to open it, help to see this help and about to read author and copyleft details. To open a database it is also required a password because they are ciphered. Use NEW button to create a new database provideing its name and password (nothing of 0 to not cypher it). Use DELETE button to delete a database to save space. After a database is opened or created it is possible to see, add and delete records. Every record is a couple of strings: key and value. Only the key will be showed in the list of records of the database. Select a record key to show its value and eventually modify or delete it with DELETE button. Use ADD button to add a new record, PASSWORD to see current password and change it, BACKUP to send all the database records in clean text format to a PC thru a serial cable getting them (by terminal program), RESTORE to add records previously backuped with BACKUP button and BACK to exit from the database. Since it is possible to add different databases, everyone may be used for a single topic.
Old 09-16-2006, 19:53   #11
Khatulistiwa
Member: 209644
BoozeCalculator v1.0 S60(java)
Calculates how many units a drink contains.
Old 09-16-2006, 21:34   #12
Khatulistiwa
Member: 209644
MORANGE Mini.v2.6.1.S60.Java.freeware
Just 250k in size, it integrates Push mail, mobile Instant messaging (MSN), Push RSS/Blog, it keep you connected with your friends and colleagues via email and IM, almost everything from mobile phone.
Our life is going mobile. We are not born to spend all the day before a PC clicking mouse, we need the true freedom to go wherever we want, to see whoever we`d like, but without losing the connection to our digital world. MORANGE keep you connected through mobile phone in your hand, and in a single application, it offers the following mobile services :
Push Mail
Real-time, secure push mail access of any public POP3/Imap email accounts with full attachment support; you can receive email on your mobile device with the same speed and reliability as that of your desktop.
Mobile IM
Instant messaging with your friends or colleagues from your mobile phone, no matter they are MORANGE users or just log in to other IM systems such as MSN and Yahoo Messenger, it simply just works.
Remote Access
You can use the virtual storage space to access, exchange and share files, photos, spreadsheets, graphics and presentations easily from mobile phone. MORANGE also allows you to fast and secure access to your desktop computer from your mobile phone and send email remotely.
Nokia Series 60 :: Nokia 3600, 3620, 3650, 3660, 7650, N-Gage
Nokia Series 40 / 128x160 :: Nokia 6650, 6651, 6820, 7600
Sony-Ericsson P800-900 :: Sony-Ericsson P800, P900, P910
Sony-Ericsson 176x220 :: Sony-Ericsson D750, K600, K608, K700, K750, V600, W550i, W600, W800i, Z1010
Sony-Ericsson 240x320 :: Sony-Ericsson S700, W900
Siemens 132x176 :: Siemens C75, CX65, M65, S65
Nokia Series 40v2 / 128x160 :: Nokia 6101, 6170
Motorola 240x320 :: Motorola A768, E1000, E1070, E680, Razr V3x
Nokia Series 60v2 :: Nokia 3230, 6260, 6600, 6620, 6630, 6670, 6680, 6681, 7610, N70
Motorola 176x220 :: Motorola A835, C975, E1 ROKR, E398, E550, L7, Razr V3, V300, V400, V500, V525, V547, V550, V551, V600, V620, V635, V80, V980
Nokia Series 80 :: Nokia 9210, 9290, 9300, 9500
Nokia Series 40v3 / 240x320 :: Nokia 6270, 6280
Old 09-16-2006, 21:40   #13
Khatulistiwa
Member: 209644
Valhalla Chat v0.2.2 S60
Valhalla Chat is an Instant Messenger for bluetooth devices.
What this means;
An instant messenger in general terms, offers (at least) typed text communication between users, just like: AIM, Microsoft messenger, Yahoo! messenger, Jabber, Skype and so on.
However, there's a big difference with Valhalla Chat and all these messaging systems. All these programs need a internet connection or at least a local network set up before connecting to each other.
Valhalla Chat doesn't need a network or any kind of setup. The two important requirements for Valhalla Chat are:
A bluetooth-able device, which can be a desktop/laptop, pda or mobile phone
To be in the signal range of at least another Valhalla chat user. Your range will be something from 10 to 100 meters.
And yes, this program is free software and will always be. Forget about "pro" , "extended" or any other fancy names to ask for money.
0.2.2b
(General binary)
BUG fixed: Application is able to execute properly wihout the "java.lang.NoClassDefFoundError: javax/bluetooth/BluetoothStateException"
BUG fixed: Some missing strings have been added to the available translations.
(Windows XP)
BUG fixed: Application won't crash when searching for rooms.
- Since 0.2.2
Desktop port multilanguage (English, Spanish and Catalan available)
User events (entered/left room)
The list of connected users is retrieved
If a user disconnects abruptly (switching off the phone) the connection is removed properly from the server.
BUG fixed: Desktop port saves and reads preferences.
BUG fixed: Desktop port uses the menus.
BUG fixed: Desktop port (WinXP) will only display "real" available rooms, no more weird services will appear as fake rooms.
Minor BUGS fixed.
- Since 0.2.1
Improved chat room interface in the mobile port (scrolling and linewrapping)
Port for pc's (tested under WinXp SP2 and Mac)
For Desktop PC(Windows XP) :
http://prdownloads.sourceforge.net/v...b.exe?download
Siemens 60 UI :: Siemens SX-1
Nokia Series 40v2 / 128x128 :: Nokia 3220, 5140, 6020, 6021, 6030, 6230, 6235, 7260, 7270
Other J2ME :: Phones that suppor bluetooth via Java [jsr-82]
Sony-Ericsson 128x160 :: Sony-Ericsson F500i, K500i, K508i, T610, T630, Z500, Z520i, Z600
Motorola 128x160 :: Motorola L6
Old 09-16-2006, 21:51   #14
Khatulistiwa
Member: 209644
JNJ.Mobile.Photo.Blaster.v1.00.S60.Java.Retail-BiNPDA
Take pictures of your friends, and then blast them with tomatoes, kisses, slime, mud and more! Photo Blaster turns your camera phone into a dangerously fun weapon. Save your favorite photos and send them to friends, or submit them for review and possible selection as a top pick!
Features :
Arsenal - Lots of fun items to choose from such as hearts, arrows, slime and more with great audio effects.
Save and Send - Save your favorite photos and share them with friends and family.
Top Picks - Submit your favorite photos to be reviewed as a possible Top Pick selection.
Nokia 3230
Nokia 3250 (S60 3rd Edition)
Nokia 5500d (S60 3rd Edition)
Nokia 6260
Nokia 6600
Nokia 6620
Nokia 6630
Nokia 6670
Nokia 6680
Nokia 6681
Nokia 6682
Nokia 6708 (UIQ)
Nokia 7610
Nokia 7710
Nokia 9500
Nokia E50 (S60 3rd Edition)
Nokia E60 (S60 3rd Edition)
Nokia E61(S60 3rd Edition)
Nokia E62 (S60 3rd Edition)
Nokia E70 (S60 3rd Edition)
Nokia N70
Nokia N71 (S60 3rd Edition)
Nokia N72
Nokia N73 (S60 3rd Edition)
Nokia N80 (S60 3rd Edition)
Nokia N90
Nokia N91 (S60 3rd Edition)
Nokia N92 (S60 3rd Edition)
Nokia N93 (S60 3rd Edition)
Old 09-16-2006, 22:13   #15
Khatulistiwa
Member: 209644
Bluejacking Easy Jack V2 + Serial
Easy jack is the latest application for your mobile to allow easy messaging to other mobiles with bluetooth in the current area, this idea has been around for a while but this application allows this task to be done easily with a lot more features than the standard send business card .
Bluejacking as it's known is widely known and is great fun and is a great way to meet new people.
Page generated in 0.16296 seconds with 7 queries
