Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Old 10-30-2006, 19:19   #1
behemot_behemot
Member: 293970
Flash BB5 to original Nokia firmware without Phoenix!
Hello,
As you might know, Nokia Software Update lets you upgrade your phone's firmware, but it will keep your operator's personalization (and revert to it, even if you flashed the phone to a non-branded firmware with Phoenix before).
ExpertGSM published a new method on a french site (www.forummobiles.com) in order to "trick" NSU so that the phone's firmware will be upgraded with the latest original Nokia firmware.
Here is the translation I've done for this tutorial - just keep in mind that you have to correctly identify (based on a firmware file for your BB5 phone) the correct product code for your country and phone model.
Here’s a tutorial that will teach you how to update your phone’s firmware to a Nokia original version (without your operator’s personalization) with NSU (Nokia Software Update – the official Nokia program).
NSU reads the product code of your phone and it searches its database for a newer version of the corresponding firmware in order to upgrade it. This is why you will need to change the product code of your phone into a non-branded product code, before running NSU.
Download the « NSS » software in order to change the phone’s product code. This is a shareware program that you can download on the site of its author here : http://bphreaks.brinkster.net/files/NSS/NSS10373b.zip
After that, download the following program: http://rapidshare.com/files/1236869/Copie_de_gsm-magic.rar.html (this is not a crack, but a program that allows the activation of any disabled option on no matter what program).
And finally, download NSU here: http://www.nokia.co.uk/nokia/0,1522,,00.html?orig=/softwareupdate.
NOW WE CAN BEGIN:
Install NSS
Install NSU
Connect your phone and wait for Windows to install the drivers.
Open NSS and click on “Scan for new device” on the right-upper part of the window
Click on the icon « Phone info »
Click on “Scan”
Open « gsm-magic » without closing NSS, then push the button « Enable » of “gsm-magic”.
As you can see, now you can change the product code (on the right of the « phone info » window of NSS). For a Nokia 6680, type the product code 0521637 (this is the product code for France!) and then mark the case “Enable”.
Now press “Write”, and your phone’s product code will be changed (you might think that nothing happened, because the phone is still in normal mode, and the changing of the product code only takes a couple of seconds, but don’t worry, the product code changed !).
Close NSS and “gsm-magic” and you can proceed now with the NSU flashing.
When the flashing with NSU is over, start-up your phone and you’ll have the pleasant surprise that your phone’s firmware is the latest Nokia non-branded firmware in date!
NOTE: I advise you to disable any antivirus and firewall on your PC during the flashing.
In order to find out the product code for other phone models, download the firmware for your phone model, connect your phone to NSS, click « Scan », then « Flash », and after that look for your product code when on « Market » you will see your country. Write down this number, then you can start the manipulation as described above. Anyway, we will soon have the product codes for all the models, so we won’t need this step.
EXPERTGSM
Old 10-31-2006, 17:20   #2
da123
Member: 333743
Good info. Just to add, the Nokia flash files come with a Readme that lists all product codes and descriptions in the package, so it's easy to choose one of the product codes to switch to without guessing.
The Following 4 Users Say Thank You to da123 For This Useful Post:
Old 10-31-2006, 17:51   #3
vertz
vertz's Avatar
Member: 173878
thanks for the info mate, it's really a big help for us.
The Following 4 Users Say Thank You to vertz For This Useful Post:
Old 10-31-2006, 20:52   #4
kabuki
Member: 381938
Only a simple cuestion if I do that in BB5 (Nokia 6131 - Movistar Spain) I obtain a free phone for use with any operator?, or only my phone have the original firm from Nokia Database??..
Thanks in advance.
The Following 4 Users Say Thank You to kabuki For This Useful Post:
Old 10-31-2006, 20:56   #5
loneunlocker
Member: 88938
Thanks in advance.
if you mean "free" as in unlocked then no .
the handset is only genericly flashed NOT unlocked.
The Following 3 Users Say Thank You to loneunlocker For This Useful Post:
Old 10-31-2006, 21:42   #6
kabuki
Member: 381938
Thanks for the fast notice.
Regards from Spain.
The Following 2 Users Say Thank You to kabuki For This Useful Post:
Old 11-01-2006, 17:59   #7
-=KaYaK=-
Member: 139155
My Orange branded N70 succesfuly unbranded/updated!
"Respect" from Poland!!!
The Following 5 Users Say Thank You to -=KaYaK=- For This Useful Post:
Old 11-01-2006, 22:51   #8
behemot_behemot
Member: 293970
great to hear that you succeeded, kayak!
The Following 4 Users Say Thank You to behemot_behemot For This Useful Post:
Old 11-02-2006, 15:28   #9
delilah
Member: 140640
first class post with instructions excellent work
delilah
The Following 2 Users Say Thank You to delilah For This Useful Post:
Old 11-02-2006, 16:19   #10
dhendriksen
Member: 382828
I have done this, and it worked great except my keyboard changed. It went from QWERTY, to AZERTY! I found a product code that worked for the keys main functions, but the sub functions are wrong (ie: symbols and such). I was going to try and describe my keyboard and find a product code to match, but here is a possibly better idea. If I understand this right, I could replace the keyboard, and get the appropriate code for the keyboard. This way I could get rid of the Chinese letters on q, w, e, a, and s. Is this correct? I appreciate your vast knowledge and input, I am glad I found this forum!
The Following 2 Users Say Thank You to dhendriksen For This Useful Post:
Old 11-02-2006, 16:20   #11
dhendriksen
Member: 382828
Where did you find this?
Old 11-03-2006, 08:39   #12
behemot_behemot
Member: 293970
you may give a try with emule - there are a lot of "exe" firmware packages, and when you install this, you'll get what da123 was talking about.
The Following 3 Users Say Thank You to behemot_behemot For This Useful Post:
Old 11-03-2006, 08:44   #13
behemot_behemot
Member: 293970
it looks like I can't edit my first post.
actually, there's no need of gsm-magic anymore.
all you have to do is install this new version for NSS which allows the changing of the product code: http://www.b-phreaks.co.uk/files/NSS/NSS10383.zip,
and then proceed with NSU.
Old 11-03-2006, 16:25   #14
Lomnica_city
Lomnica_city's Avatar
Member: 275559
Yup,I forgot to tell you that,but I figured that out few days ago,but Serbian forums were my priority and I forgot to say to the others here that latest version of NSS doesn't need that crack (or cheat) and this makes the process of changing the code faster and easier!!
It would be nice to make a list of product codes for some areas,and in your first thread above this one I gave a list of 4 product codes for N70 and N72 for entire Balkans area (which covers nealy 10 countries) and now others should help out!?
Pozdrav
The Following 4 Users Say Thank You to Lomnica_city For This Useful Post:
Old 11-03-2006, 17:29   #15
desgrassia69
Member: 66466
Smile N70 product codes
here I am attaching all N70 readme files for packs 8.xx. inside you can find all the product codes
i.e.
- RM84_50616203_V2.V01 Euro-1
*0523737 Euro-1
*0522157 Euro-1
*0533531 Euro-1
*0523980 France
*0523982 France
*0533652 France
*0523985 Alps
*0523986 Alps
*0533653 Alps
0523737 is one product key for Euro-1
and so on
you can find readme files when you install the package, they will be put inside the Product folder in program files\nokia\phoenix\products\rm-84 (for example)
I renamed them 'cause I use to save them together with .exe package installers
hope this helps
The Following 8 Users Say Thank You to desgrassia69 For This Useful Post:
Page generated in 1.01343 seconds with 7 queries
