Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
04-07-2007, 20:32 | #3 (permalink) |
Registered User Join Date: May 2006 Location: Uzbekistan
Member: 284250 Status: Offline Thanks Meter: 5 | Device = USFx HWK Cable = A300 Select Model = X480 Press Mobile Info and then Press Unlock 10000000% Work Software: X475UVEB2 Hardware: REV0.400 Imei: 356299-00-485883-1 Lock Level: 01h SProv Code: ffh IMSI Mask : 41h 00h 10h 00h 00h 00h 00h 00h PCK : 00000000 NCK : 38765055 SCK : 38765055 SPCK: 38765055 MCK : 32579629 Clear SPLocks Done, Time: 00:01 Clear SimLock Done, Time: 00:01 Clear UserLock Done, Time: 00:00 Unlock Done, Time: 00:03 |
11-19-2007, 07:51 | #6 (permalink) |
Junior Member Join Date: Oct 2007
Member: 620662 Status: Offline Thanks Meter: 3 | Samsung X450 (also works on samsung E810 / c260 / X470 / X475 and more- tested by said ali Comoros 1) note handset imei 2) insert the card you want to use in your handset and switch on 3) at wrong card enter *2767*688xxxxxxxxxxxxxxx# (xxxxxxxxxxxxxxx = handset imei number) 4) after reboot your sim will work, BUT not after power down now the trick: 5) enter *0141# 6) press call (green) button 7) now simlock updated to current network good luck |
The Following User Says Thank You to saidali18 For This Useful Post: |
12-08-2007, 15:43 | #7 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | Quote:
Odia the ultimate--need help for x475 | biochemistali | HWK | 5 | 01-10-2011 15:32 |
--= PROMOTION - C O N T I N U E S !!! : All A1/A2/S1 unlocks FOR FREE till Apr 12 =-- | Mizar | Cruiser Suite | 387 | 04-30-2010 16:25 |
need flasher and flash for X475 | IkaMazini | Samsung Flashers, Software, Firmware. | 2 | 12-08-2007 03:20 |
to those who wants to unlock samsung x475 | obioha | powerflasher | 7 | 04-11-2007 18:20 |
unlock samsung x475 | STOMATELA | UFS2 + UFS3-Tornadoflasher | 9 | 09-10-2006 18:31 |
