Old 12-08-2006, 22:00   #1
gabriel148
Member: 209095
how to conect grundig g410i
im try unlock this phone, and never connect.
i use the manual step by step, and not conect
the cable work fine in aira 340 etc, and in 2 grundig slider, neves conect.
i connect the phone in pwr off and not conent ( many times make knoice) and when try power on, nothing!!!
help me
Old 12-08-2006, 23:23   #2
Dayratel
Member: 55654
help me
Plase try tu put all the stpes that are you doing for help you!
(You can use IRDA Connection (Swith on phone), or Cable Connection (Switch on phone and simcard of the operator locked).
Take a look in Hardware administrator for see that all it´s ok too.
Regards
Old 12-09-2006, 21:04   #3
gabriel148
Member: 209095
im use usb cable.
when conect the cable poweer off the phone, but never ,notconection, not driver, nothing nothing, only mak ea knoice many times, and when power on the phone, nothing again
Old 12-10-2006, 02:41   #4
Easy-Unlocker
Member: 401002
im use usb cable.
If doesn´t connect, take a look of your accesory connector. Should to be ok.
Any way you can try to unlock by IRDA Connecion. Only have to activate IRDA in mobile phone, and connect with IRDA for unlock. Try this if not connect by cable.
B Regards!
Old 12-13-2006, 22:46   #5
gabriel148
Member: 209095
for cable is impossible, but whit irda works fine.
very good job unlock in 2 seconds!!
Old 12-14-2006, 00:54   #6
Dayratel
Member: 55654
probably the error was in the accesory connector.
Regards!
Old 12-15-2006, 02:11   #7
Daeron
Daeron's Avatar
Member: 104840
Sonork: 100.106901
im use usb cable.
Has you put a correct sim card insede?
Old 12-21-2006, 11:04   #8
littmanr
Member: 190377
Hi ,,can I use any IRDA device,,example usb ma-620??,,,for irda is necessary Sim Card inside??...
BR.
Old 12-21-2006, 12:48   #9
aErOm
aErOm's Avatar
Member: 7900
Sonork: 100.78126
BR.
Almost all IRDA are supported by the Application and for procedure of how to unlock, please take a look at the manual, it´s well specified.
Best Regards !!
Page generated in 5.36378 seconds with 6 queries
