![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004
Member: 97600 Status: Offline Thanks: 70
z540 not unlocked any help
Phone info:
~~~~~~~~~~~ Phone Model: SGH-Z540V Revision: Z540BUFE4 IMEI: 3584************ Manufacturer: SAMSUNG ELECTRONICS CORPORATION Reading data from phone... ERROR - Can't get simlock data from phone! |
#2 | |
![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 401002 Status: Offline Thanks: 1
It“s problem of software. B Regards! |
#3 | |
For this phone models (z540 simlock problem) is better use flash method instead of normal with phone on. BR Easy unlocker Team |
Ok i flashed phone with Z540XXEF1 and the result is the same cant read codes so please explain this "v1 with flash mode method" as its not in the manual and i cant find a samsung v1 in support. Thanks
![]() ![]() ![]() ![]() Join Date: Jan 2004
Member: 51463 Status: Offline Thanks: 4
hello Easy unlocker master
i have this version phone in hand Z540V , i try to flash to Z548 chinese and Z540 normal flash , but server same , Can't read the phone , please master advice some solution to fix phone , ( Z400 and ZV40 i unlocked is no no no problem ), |
#6 | |
![]() ![]() Join Date: Oct 2004
Member: 88831 Status: Offline Thanks: 0
z540 unlocking
to unlock z540 use the code *#7465625228# with out sim card. |
#7 | |
Member: 23420 Status: Offline Thanks: 21
i found it exists on the net but i cannot download, or find in support area |
Member: 68597 Status: Offline Thanks: 5
#9 | |
Member: 55654 Status: Online Thanks: 22
Phone On with a sim card of diferent operador (and put the pit if ask your phone for him). Click on read codes, and if don“t receive the codes is problem about the flash of the phone. You should to reflash the phone. You should to reflash the phone too if don“t receive codes (problem is that are bad the data of sim lock area in phone). Regards! |
Member: 50272 Status: Offline Thanks: 14
just use simcart which is wihtout pin code. and try again.
the new version v1.03 worked perfectly on z540 great piece of kit well done easy unlocker team
Member: 830875 Status: Offline Thanks: 0
This method is exactly what is being sold on Ebay for £1.00+
If you have a Vodafone Samsung Z540 (Z540v), you can bypass the Network lock. First of all remove your sim card from the phone. Switch on the phone. Key in: *7465625*228# Switch off the phone. Insert the sim card of your choice and switch your phone on again. Your phone should now be accepting your sim card. |
| The Following User Says Thank You to Z540 For This Useful Post: |
#13 | |
![]() Join Date: Oct 2006
Member: 362369 Status: Offline Thanks: 0
its work 100/100 thanks |
Member: 80354 Status: Offline Thanks: 586
welcome, but you're open too old thread,
anywayimportant your problem solved, thread is not important for us |
