Old 12-23-2006, 17:39   #1
tobi3
Member: 295256
TSM7 unlock procedure
What is procedure for unlock TSM7 please hlp
Old 12-23-2006, 19:47   #2
Dayratel
Member: 55654
You can use IRDA Connection or cable. Only have to connect normal for unlock it.
Regards
Old 12-23-2006, 20:03   #3
tobi3
Member: 295256
need pin out fo tsm7 and m131 in suport not picture
Old 12-23-2006, 21:35   #4
Gsmsassa
Gsmsassa's Avatar
Member: 142001
Use irda Work Fine
B.R
Gsmsassa
Old 01-07-2007, 18:00   #5
nefhamid
Member: 49066
please more detail sir.
Old 01-07-2007, 18:32   #6
Ibn'arabi
Ibn'arabi's Avatar
Member: 66566
Hi
I think you just have to use an infrared installed on your pc (as usb bluetooth) and see in device manager witch com it takes, that's it, no need pinout
and try and post result
B.r
Old 01-07-2007, 20:35   #7
Shaytan CrKdz13 ltd
Shaytan CrKdz13 ltd's Avatar
Member: 111121
Sonork: 99340 : CrKdz13
1st u cant unlock TSM7 with cable only by irda , use the irda to install your TSM7 like modem without driver , driver must from Windows Xp , and chose on the soft the com number of the installed modem
Old 01-07-2007, 20:36   #8
Shaytan CrKdz13 ltd
Member: 111121
and olso other thing , after the big boom of the Samsung update , now where is the support team ?
Old 01-07-2007, 22:04   #9
georgegsmro
Member: 185422
conect to irda (notebook irda tested ok) wait for detected device and start grundig 2g program and read codes .work fine
Old 01-08-2007, 16:45   #10
aErOm
aErOm's Avatar
Member: 7900
Sonork: 100.78126
The support team has been having a well gained Rest, after the hard workd developed, now with new year 2007 are back to work hard to offer you and all EUb users usefull updates, so please be patient, we´re keep on working.
Best Regards !!
Old 01-11-2007, 15:36   #11
debeliamark
debeliamark's Avatar
Member: 4627
I still can't get it working - on COM port IRDA ( used with success for TSM30 and 100 and redbox ) nothing - can't communuicate, using USB MA-620 and IRCOM application comunication exist ( some sandclock on TSM-7 screen ) but Windows can't recognise TSM-7 device ( drivers missing ) and Grundig 2G give :
Connecting to phone...
ERROR - Bad answer #11
so - more detailed info be welcome
Old 01-11-2007, 21:34   #12
iziki33
iziki33's Avatar
Member: 107925
seem problem in g2 cant connect with phone driver 2g installed but som driver missing i use test card mortorola
in my laptop irda work but c ant detect phone!
this is message i receive :Connecting to phone...
what the problem
grundig m130 unlocked ok
grundig 402i no chance!
Old 01-12-2007, 06:41   #13
debeliamark
Member: 4627
I have resolved mu conection problem with TSM7 - just install some old version of IRCOM and point IRCOM virtual port to figure lower that 8 - all work just fine.
Old 01-12-2007, 07:07   #14
GSM Brothers
GSM Brothers's Avatar
Member: 2203
what the problem
use usb cable and put test card inside and select backup phone mode and unlock in 3 sec
Old 01-12-2007, 11:14   #15
aErOm
aErOm's Avatar
Member: 7900
Sonork: 100.78126
If you´re xpermimenting some connections problems via IRDA, may be a problem caused for many things like your PC Port, like config, like not well installed IRDA, many many things can be, so if you follow GSMBrothers advice to use USB cable you will fix all the problems and all will run ok.
Best Regards !!
Page generated in 0.29451 seconds with 7 queries
