![]() ![]() ![]() ![]() Join Date: Dec 2003
Member: 45796 Status: Offline Thanks: 2
Alcatel VLE5 ????
Thoes the Easy-Unlocker support unlocking newer version of software for VLE5 phones ?
Member: 14468 Status: Offline Thanks: 13
yes i tested on e257xx that other sw give smiley code
easy unloker give correct code best regards vali |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005
Member: 131118 Status: Offline Thanks: 43
Hi
work well with old versions but when i try to unlock new ones it says understand if u can BR |
Member: 23420 Status: Offline Thanks: 21
i tried today with e259 but it's not okay..
it says power on phone, i pressed powerbutton on phone, or used auto ignition.. but it's not starting.. i also tried with usb smart -> error starting bootloader and some free programs are giving only garbage back.. so it seems there is still some work for EuB Unlocking samsung with it is working perfect.. good job |
#5 | |
![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 401002 Status: Offline Thanks: 1
Please look the cable, and retry to make it. Should be works fine. B Regards! |
![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004
Member: 64213 Status: Offline Thanks: 33
Is Best Solution For Alcatel
WORK FLASH SPEED AND FULL REPAIRE
U CAN ADD ALL FLASH DOWNLOAD BY FROM SUPPORT ADD TO FODER "DATA" for u can flash and soft reconized firmware |
