Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > LG
Old 01-04-2007, 08:46   #1
apolux_x
Member: 144365
Free unlock LG KG800
use rj45 universal pinout.You must have vygis crack.Start 1.43 (vygis 2g) use boundrate 115 200. select in list F2400 and press connect .You ill get message ''flash not supported yet''. start enforcer ,press enable, press ok to vygis message and then just press unlock allthow the unlock button is grey. Enjoy TEST ON 10 PIECES WORKS 100%. Please post your results.
The Following 14 Users Say Thank You to apolux_x For This Useful Post:
Old 01-04-2007, 16:22   #2
colepipo
Member: 153875
Is the Method really working
Is this solution really working brothers? Any other person who has tried this please post the results.
Old 01-04-2007, 19:07   #3
samusprime
samusprime's Avatar
Member: 189984
Angry ummmm
really works????
Old 01-04-2007, 22:07   #4
gus0909
Member: 386713
Not Work A Tri In Not Wrok Sorry
Old 01-04-2007, 22:07   #5
gus0909
Member: 386713
UNLI SEY THIS Please plug cable to phone.Phone must be OFF.If bootloading not starts - press power ON and keep it pressed until boot loading will be finished.
Disconnected by user
Old 01-05-2007, 09:05   #6
apolux_x
Member: 144365
use correct cable select F2400 press connect and press power on untill you will get the message ''flash not supported yet'' start enforcer and press enable , press ok to message and then unlock. must work 10000%.please trie and post
Old 01-05-2007, 09:22   #7
colepipo
Member: 153875
which cable to use on this LG KG800?
Can someone please tell me which cable to use on this type of LG?
Old 01-05-2007, 09:37   #8
::.imeimate.::
::.imeimate.::'s Avatar
Member: 177834
have u tried it b4 posting !!!!
Old 01-05-2007, 09:39   #9
apolux_x
Member: 144365
use search button.you can modify original cable to rj45 Buy connector Female USB (see attech picture)
2.Take any standart data COM cable (RX,TX,GND)
3 Use original USB cable.
http://forum.gsmhosting.com/vbb/showth...t=kg800+pinout
Old 01-05-2007, 11:22   #10
apolux_x
Member: 144365
it realy working .i'm not posting just for posting if is that what you mean.believe me it's working 10000%
Old 01-07-2007, 00:34   #11
laboratory_gsm
Member: 160001
pressed until boot loading will be finished.100/100
my pc restat ??????
Old 01-07-2007, 02:00   #12
mobi4u
Member: 64908
yurs vigis is not crack properly just install the 2nd file
this is yurs installation foult
Old 01-08-2007, 18:57   #13
foppa21
Member: 171785
Tested, working 100%
use boundrate 460 000 ...
Good solution!
Old 01-08-2007, 19:06   #14
abdulwajid147
abdulwajid147's Avatar
Member: 213172
Sonork: 1582799
thanx for this unique solution...i hope you are Right 100%
Old 01-09-2007, 09:43   #15
apolux_x
Member: 144365
i'm glade that you menage to use my solution.please use it and post results
Page generated in 0.10119 seconds with 7 queries
