Old 01-12-2007, 11:34   #1
ringtons
ringtons's Avatar
Member: 97600
zv40 unfreeze help
i have generated the codes for unlock and defreeze but when i input the unfreeze code there is no ok button to press which one is it have tried right hand top and end call no good if i try left hand top or call it does a sos call any help please
Old 01-12-2007, 11:37   #2
aErOm
aErOm's Avatar
Member: 7900
Sonork: 100.78126
Only need to push GREEN BUTTON, if does not work is a flash corrupted problem and you´d need to flash your phone first to correct flash wrong data.
Best Regards !!
Old 01-12-2007, 11:46   #3
ringtons
ringtons's Avatar
Member: 97600
thanks for that it seems it is the problem
Old 01-12-2007, 11:51   #4
aErOm
aErOm's Avatar
Member: 7900
Sonork: 100.78126
ok, post results once flashed.
Best Regards !!
Old 01-12-2007, 16:03   #5
ringtons
ringtons's Avatar
Member: 97600
flashed phone but still the same had to use fastmultiloader to flash as nspro reported a fault in modem file and could not continue. have returned phone to customer for now
Old 01-12-2007, 17:47   #6
aErOm
aErOm's Avatar
Member: 7900
Sonork: 100.78126
Then is a flash problem of the phone as we suggested, I wish you best luck in your next Zv40 for you to see how fast is Unlock with EUb.
Best Regards !!
Old 01-15-2007, 16:32   #7
merakli75
Member: 56884
Zv40 Unfreeze
Zv40 Unfreeze Help...
Old 01-15-2007, 18:31   #8
alfred62
alfred62's Avatar
Member: 67750
You must explain more ab your trubble
???????? please tell us what you have tryed and how you did
Regards
Old 01-15-2007, 23:05   #9
ringtons
ringtons's Avatar
Member: 97600
Best Regards !!
i have no problem with this equipment i have unlocked several z series up to now and no problem i recommend it.
Old 01-20-2007, 14:58   #10
ZerGoS
Member: 12242
for unfreeze the phone you have to put simcard inside, enter unfreeze code (not appair at display) and press "OK" butom it should be the cross center butom, or up left right one.
Post result
Old 04-06-2007, 14:58   #11
nizou_gsm
nizou_gsm's Avatar
Member: 304362
but how to get the unfreezing code ?
Old 04-09-2007, 10:21   #12
aErOm
aErOm's Avatar
Member: 7900
Sonork: 100.78126
You have english version of manual in support section, take a read please, and if your problem is not solved contact me by PM.
Best Regards !!
Page generated in 0.10087 seconds with 6 queries
