Member: 38980 Status: Offline Sonork: 100.84054
my new dreambox 2 didnt even work for a minute!!!!
--- Updating Box Firmware------------------------------------------------------
Connecting to server ...OK Warning : Update not found. There are no new updates on server or your device is already up to date Done. --- Reading Box Info----------------------------------------------------------- Box SN : XXXX Firmware Version : 0 Firmware Build Info : 2329 19 May 2006 15:00:02 Hardware version : 1.2 Done. what shuold i do? |
Hello, Dj_SiGma!
Please, send me by PM a serial number of your box and we will help you. |
still not working !
![]() ![]() ![]() Join Date: Dec 2005
Member: 214480 Status: Offline Thanks: 28
Try to update it again now.
Member: 69250 Status: Offline Thanks: 3
hi best team
Mr i have a big problem with mu dreambox when i do any operation it say battery volt 0mv power is shorted to ground whan i habe opened the box i found the the diod B2 is damaged near the usb port with witch one i can repalece them thanks in advance Abdelouahab its very very emergency i wait your reply verry verry soon bibi192004@yahoo.fr |
To bibi019
Please check your mailbox. |
![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 170968 Status: Offline Thanks: 1
#9 | |
i think i blew a diode near the usb. due to grounding or wrong testpoint. anyway i substituted the SMD diode with a low wattage type and the box is working now.... can you post the value and power rating of the original SMD diode here so that users can find the replacement part and keep to the box's specs ? br |
#10 | |
We replaced this diode by resistor in new DreamBox Plus. |
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 300540 Status: Offline Thanks: 4
Hi ! shall b grateful if u kud specify resistor value in ohms with modification schematic. U shall agree as this a matter of product improvement, thus mimizing downtime ! Best regards,
Member: 229780 Status: Offline Thanks: 0
hi. use resistor: 5.6 ohm + 5% 0.25 Watt minimum
hi i have alredy the probleme in my dreambox always it say power is shorted to ground inside the box i found the the diod B2 is damaged near the usb port i changed them with resistor 5.6 ohm the problem still now i want to try the change in BoxImproveManual witch you have send to me but i can't find th max810r sheet any where if you can tell me where i can found it in ant motherboard of pc or cellphone or any things because i don't find them at salle
thanks in advance i wait you reply best team bibi192004@yahoo.fr |
To bibi019
Hello!
Please, check your PM. Thanks. |
