![]() ![]() ![]() Join Date: Dec 2005
Member: 214480 Status: Offline Thanks: 28
DBSS v2.3.3
Dear users,
We are pleased to announce a release of new versions of DBSS v2.3.3 In this update: Improved flashing algorithms for AMD based handsets. More features to come. Best regards, GSMDream team DreamBox - Get more with it. |
Member: 132334 Status: Offline Sonork: 100.87489
Great Work GSMDream Team.
Keep it up ![]() WBR Nadeem Shahzad |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004
Member: 68498 Status: Offline Thanks: 43
Thanks for the update
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002
Member: 8353 Status: Offline Sonork: 113276
thanks for giving more power to dreambox
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005
Member: 137474 Status: Offline Sonork: 100.109924
I can't boot C60 with this update with TP why ???? Phone have INTEL chip and boot without problem with martech with TP why in this version not boot ?? ?? ??
#6 | |
Could you boot C60 with previous version of DBSS? Can you boot other phones with this update? Please, explain why you can not boot with TP. Do you get some errors? |
With version 2.3 I boot without problem but with 2.33 not. Software not detect that I conect TP. nothing only wait wait and nothing.
This is a log from dss2.3.3
[26/01/2007 18:28:34] --- Unlocking------------------------------------------------------------------ [26/01/2007 18:28:37] User selected phone C60 using Test Point boot mode [26/01/2007 18:28:38] [26/01/2007 18:28:38] Power On the phone ... OK [26/01/2007 18:28:38] Hint : Please connect the probe with a button to testpoint [26/01/2007 18:28:38] as shown in the description and wait. |
#10 | |
Please, check your TP cable. Maybe it is damaged. |
Member: 138575 Status: Offline Thanks: 7
Sir,
I have purchased a new box, with any operation I get eroor stating to update Box. When I try to update box, I get errror as follows --- Updating Box Firmware------------------------------------------------------ Connecting to server ...OK Warning : Update not found. There are no new updates on server or your device is already up to date Done. --- Unlocking------------------------------------------------------------------ Error : You have not update your box, please do it. Error : can not connect to Dream Box ( XXXX) Error : Failed. Please help me soving this problem. Br jackle123 |
Give your box's serial number by private message to me.
![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 170968 Status: Offline Thanks: 1
same problem using TP on A-60....i switched back to ver. 2.2 and it worked...
btw the phone was in for unlocking |
Member: 164786 Status: Online Thanks: 55
Support...
again, again... New version and SCENARIO mode doesn't work fully... Flashing a BIN file in IMEI mode: SELECT - WRITE FULL FLASH SELECT - REPAIR IMEI SELECT - UNLOCK ALL LOCKS But only WRITE FULL FLASH is made! Need to repair IMEI manually. Tested now with A65 AMD Chip. I said it in 2.2, 2.3 and now in 2.33. When the support will correct this simple thing? 2.99? |
Thx for report - we will correct it.
