![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2004
Member: 78619 Status: Offline Thanks: 157
whats wrong with c75
dear sir i recieved c75 on beep today which went to this on free unlocking soultion try ...
i flashed it but same result whats else i should do... log i s here Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM ...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash IMEI = 356272-00-399140-8 Bootcore: SIEMENS C7V Warning : Check phone model selection. Firmware: SIEMENS C75 v13 lg95 Warning : Firmware info different from Bootcore.!!! Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Setting IMEI = 356272-00-399140-8 Writting speed is 64746 cps Hint : Please connect next phone Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM ...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash IMEI = 356272-00-399140-8 Bootcore: SIEMENS C7V Warning : Check phone model selection. Firmware: SIEMENS C75 v13 lg95 Warning : Firmware info different from Bootcore.!!! Phone IMEI = 356272-00-399140-8 SPLock CRC = OK Phone Code = < NOT SET > : FF Setting IMEI = 356272-00-399140-8 Writting speed is 64912 cps waiting for ur reply br khalid |
![]() ![]() ![]() Join Date: Dec 2005
Member: 214480 Status: Offline Thanks: 28
Sorry, but I can't understand what do you mean...
its mean phone is dead
dear sir its mean that set is still dead how to revive this phone ...
when i power on the phone it only give beep and nothing else ... what i should do know.. thanks for ur reply br khalid |
#4 | |
Please, do the next: 1. Select Options -> Siemens -> Repair setup table after flashing firmware area. 2. Select Options -> Siemens -> Repair IMEI after flashing EEFULL or EELITE area (use OTP IMEI). 3. Run Repair IMEI (Use factory IMEI from flash OTP area). Last edited by DreamSupporter; 02-08-2007 at 12:13. |
Member: 121585 Status: Offline Thanks: 0
i had the same prob. now its ok but the phone reset when the sim in it . its ok with out sim only
#6 | |
![]() ![]() ![]() ![]() Join Date: Sep 2006
Member: 355635 Status: Offline Thanks: 264
try to flash the phone again DON"T FORGET the way like dreamsupporter said after flashing, DO repair securities data, don't forget cek the use imei from flash OTP and then do unlock all lock, i try flashing this way in 5 phone c75 and it's 100% succes sorry bad english BR notgood |
![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 402075 Status: Offline Thanks: 9
flash it again then repair imei using otp imei, then unlock it.
![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 246444 Status: Offline Thanks: 54
c75
I have same problem with c75.i try to full flash but nothing.i just want to unlock but the phone become dead.
Read phone info User selected phone C75 using Test Point boot mode Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM ...OK Flash Chip = AMD S29WS256N, size 32768 Kb Flash IMEI = 357982-00-438386-3 Phone ID = 470EC5C1 Bootcore = SIEMENS C75 Firmware = SIEMENS C75 v24 lg7 Full flash process User selected phone C75 using Test Point boot mode Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM ...OK Flash Chip = AMD S29WS256N, size 32768 Kb Flash IMEI = 357982-00-438386-3 Phone ID = 470EC5C1 Bootcore = SIEMENS C75 Firmware = SIEMENS C75 v24 lg7 File name : D:\DREAM BOX\C Series\C75\C75_110300.fullflash.dtf Address : 008000 (95638 cps) Thanks |
Hi, vampire13!
What version of DBSS do you use? Write fullflash from our support section at www.boot-loader.com. And run Repair Security Data (Use factory IMEI from flash OTP area). |
c75 problem
use latest version DBSS 2.5.flash process always stop.
![]() Phone was dead when i try to unlock. Thanks dream supporter |
Please, try to use Force "Safe mode" option.
C75
Still not working.always hang at this process.
Many thanks |
