![]() ![]() ![]() ![]() Join Date: Nov 2004
Member: 89661 Status: Offline Thanks: 4
Eub Bad Support Team
Hello! anybody there?.
For the past four days all the posts here are left unreplyed from eub team. Please dose anyone know the right cable for unlocking z560 ? I called jan farrell just for simple Q but all he could say is send me an email when they could not reply forum posts. I spent almost ERU350 for this dongle only to found out that there is no support. NO THANKS |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
Member: 3783 Status: Offline Thanks: 10
d800 usb cable will make the job for u...
![]() ![]() Join Date: May 2006
Member: 275692 Status: Offline Thanks: 0
same problem with me.. pls help with topic "URGENT PLS!! Alcatel E801 not connecting".
About alcatel .... really can´t help u friend
#5 | ||
Member: 55654 Status: Offline Thanks: 22
First read and search by forum before to said some things You shoud to use service cable for Samsung V804 (connected by USB and COM Port together to the computer) Quote:
Regards |
#6 | ||
![]() ![]() ![]() ![]() ![]() Join Date: Dec 2001
Member: 7900 Status: Offline Sonork: 100.78126
SECOND JUST WHEN I CONNECTED AGAIN THE FIRST THING I DID IS ANSWER ALL POST STARTING FOR THE OLDER. THIRD YOU MUST NOT SAY ANYTHING ABOUT SUPPORT BECAUSE THE FIRST THING YOU MUST DO IS READ MANUAL AND NOT ASK THINGS EXPLAINED IN MANUAL, IF YOU HAD INVESTED YOUR TIME READING MANUAL AND LEARNING HOW TO USE EUB YOU´D HAVE NOT POSTED SUCH POSTS... MAN TAKE IT EASY AND DON´T MAKE THINGS WORST FOR ALL - LIVE AND LET LIVE - STOP COMPLAINING WHEN YOU´RE NOT IN REASON !!! Quote:
Best Regards !! |
#7 | |
#8 | |
That´s explained in EUb user´s manual... Best Regards !! |
support access problem solved but z560 unlock problem still remain unsolved even after uninstalling and reinstalling samsung usb driver.
I tryed with z400 original usb cable and still same problem. COM4(SAMSUNG CDMA MODEM). Any other way to solve this problem ? Br lins97 |
#10 | |
About your second problem, have you tried with V804 Cable which comes with USB and RJ45 port? you have to connect both and this way yoou´ll be able to unlock.... this is how we do and never had problems. Please report me results. Best Regards !! |
