Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > GSMServer Products > DreamBox
Old 02-17-2007, 14:52   #1
07heaven
07heaven's Avatar
Location: www.07heaven.com Midlands, UK & Larnaca Cyprus
Member: 57937
C72v issue
Had a C72v for unlocking, choose test point method, selected C72v.
and the following log came up:
- Unlocking------------------------------------------------------------------
User selected phone C72V using Test Point boot mode
Warning : You should conect power to your phone
Power On the phone ... OK
Hint : Now the probe might be disconnected
Sending loader ... OK
Testing RAM ...OK
Flash Chip = AMD S29WS256N, size 32768 Kb
Flash IMEI = 357364-00-515843-0
Bootcore: SIEMENS C72V
Firmware: SIEMENS C72 v22 lg1
Warning : Check phone model selection.
Warning : Firmware info different from Bootcore.!!!
Error : Please select correct model.
Hint : Strict model validation is turned on
Error : Failed.
So then choose, C72, and got the following log:
User selected phone C72 using Test Point boot mode
Testing RAM ...OK
Phone IMEI = 357364-00-515843-0
SPLock CRC = OK
Phone Code = < NOT SET > : FF
Writting speed is 240 cps
Done.
Old 02-19-2007, 09:34   #2
DreamSupporter
Member: 241271
Hello, 07heaven!
Please, select Options -> General -> Disable strict model and firmware validation.
The Following User Says Thank You to DreamSupporter For This Useful Post:
Page generated in 0.06090 seconds with 6 queries
