![]() ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 281857 Status: Offline Thanks: 195
c65 big problem need help
i received c65 for arbic language at flashing stop on 54% i try to flash it with full flash but stop again in 9% then i use flash file from support in folder (ut) phone accepted the flash put did not work pls help
Hello, habeebo!
Please, do the next: 1. Select Options -> Siemens -> Repair setup table after flashing firmware area. 2. Select Options -> Siemens -> Repair IMEI after flashing EEFULL or EELITE are (use OTP IMEI). 3. Write full flash file from our support section at www.boot-loader.com. 4. Run Repair IMEI (Use factory IMEI from flash OTP area) if you still can not turn on your phone. |
i did what u said .but i found that phone is ct65 and firmware is c65 is this make any change. if its where can find full flash for ct65 or how can fix it
Just select Options -> General -> Disable strict model and firmware validation. And write full flash from C65. The phone will work, but will have a firmware from C65.
