Member: 164786 Status: Offline Thanks: 55
I already sent a PM for support, but doens't work the REPAIR SECURITY for DreamBox "unlock dead" SL75.
You will get again "Write #06" error. The flash process only starts before you untick * Options -> Siemens -> Repair IMEI after flashing EEFULL or EELITE are (use OTP IMEI) * Options -> Siemens -> Repair setup table after flashing firmware area Flash occours normal, but when you try to repair IMEI again the "Write #06" error. DreamSupporter, when will we wake up from this nightmare? Thanks in advance! |
Hi! It's time to fix your dead SL75 flash ID AMD!
![]() If you tried to unlock an SL75 and received this error: Error : Write #06 And your flash info are: Flash Chip = AMD S29WS256N, size 32768 Kb Make all the steps and you will get your phone live again. 1 - Install DBSS 2.4 and upgrade the box firmware. 2 - Download the fullflash "SL75_lg3_v10_fullflash.dtf" from www.boot-loader.com 3 - In DBSS 2.4, Tools -> Options -> Siemens and tick: 4 - Now select model "Siemens SL75" and the access mode: 4a - If you have keys, use IMEI Access Mode.5 - Go to "Scenario" tab and select the "SL75_lg3_v10_fullflash.dtf" and check "Write Full Flash" 6 - Select "Manual Restart" and click "Run Scenario" 7 - It will take 12~15 mins, when it ask about the other phone, cancel, remove data cable and the battery, wait 5 secs, insert the cable and the battery 8 - Uncheck "Write Full Flash" and check "Generate Randon Skey" and "Repair Security(use factory IMEI from OTP area") - EDIT:You can use "Normal Access Mode" now. 9 - Again will take 12 ~15 mins, but it's ok, it's repairing process. OK, remove and insert again the battery and now your phone is working good, but if you need change the language pack do it in "Scenario" tab checking only "Write Firmware" and "Write Language". Try to use a v10 firmware or the original version of your phone. I used a new test point discovered by gehstock/BouRRi_GSM and works very good with DreamBox too! Don't need to use the DreamBox TP needle, use a common needle to that point to GND. EDIT: Use it in your own risk. See in next post what DreamSupporter says about this TP. Thanks DreamSupporter, gehstock and BouRRI_GSM! Last edited by paullovinicius; 02-23-2007 at 17:07. Reason: Adding info about new TP |
We don't recommend to use this TP, because it can be dangerous for your phone!
@ paullovinicius, moaster and their friends Thank you very much for help in testing SL75 with AMD flash! |
![]() ![]() ![]() ![]() Join Date: May 2003
Member: 27956 Status: Offline Thanks: 23
Didn´t work... error #06 on step 8.
tried on step 8 "Write EEPROM" and it goes to end but phone still doesn´t power on. flash used sl75_1003[1].fullflash.dtf 06-28-2006 14:12 from bootloader Last edited by paulo_mineiro; 03-01-2007 at 02:12. |
Alternative STEP 8:
8 - Uncheck "Write Full Flash" and check "Write EEPROM", "Generate Randon Skey" and "Repair Security"(use factory IMEI from OTP area"). paulo_mineiro, try to do it or go to EIL forum :-) Portuguese Procedure is posted there
![]() ![]() ![]() ![]() Join Date: Apr 2004
Member: 62561 Status: Offline Thanks: 5
Yes, Many times tested. It works!
b.r. Cryspim |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005
Member: 111457 Status: Offline Thanks: 300
with This TP risk is 0
repair/unlock more than 30 SL75 or dead SL75 with this TP, worked phone never dead, dead phone will alive many memeber have tested this TP 2 month ago and can confirm phone never dead with this TP so where is the risk?? sorry i'm in wrong section
@paullovinicius
Maybe my fullflash is old, I am trying to download a new from bootloader but it is impossible... @BouRRi_GSM I think: this process must be done quickly. like x65 TP if you conect for a long time will damage the phone. This is a simple and rapid solution. @DreamSupporter Please, correct me. |
@DreamSupporter
now my SL75 is alive with SL75_lg91_v39_fullflash.dtf others FW versions didnīt works if I update only lang from sl75_390100.update.firmware.dtf kill my phone can you help me? |
To paulo_mineiro
For now we recommend you to use scenario in DBSS for SL75:
- Open the file Sl75_390100.update.firmware.dtf - Select only Write language - Run Scenario and all will be OK .
paulo_mineiro, where i can found this fullflash?
i only found "SL75_lg3_v10_fullflash.dtf" in boot-loader.com DreamSupporter, can I use a backup from a working SL75/AMD phone instead use the SL75_lg3_v10_fullflash.dtf ? My phone doesn't shutdown(freeze in last "Siemens" black screen...) Thanks! |
A full backup from a good phone didnīt work.
SL75_lg91_v39_fullflash.dtf with Lang from a good phone fullbackup didnīt work. SL75_lg91_v39_fullflash.dtf with Lang from sl75_390100.update.firmware.dtf downloaded from bootloader alive my phone with some bugs. Freeze some menus,mixed lang (portuguese and russian) and some funcions of the phone become to slowly.Shutdown takes more than one minute. My old fullflash downloaded from Bootloader isnīt the same I got now. (old sl75_1003[1].fullflash.dtf 23.294kb and new SL75_lg3_v10_fullflash.dtf 23.410kb) |
paulo_mineiro, are there any differences using the old and new v10 fullflash?
talking with gehstock, he said me that the freeze at shutdown is caused by use a non original from my phone eeprom and/or FFS. he have same problem with EL71 and all new-sgold.... DreamSupporter, we need help again to solve the "unshutdownable"(bad word ), mixed languages and buggy SL75, ok?We are waiting! |
