![]() ![]() ![]() ![]() Join Date: Jan 2002
Member: 8801 Status: Offline Thanks: 0
„Gsm_sim2c“ versus „Sim_Emu 4.00“
Gsm_sim2c by Alf
„+“ display number of currently selected card easy change number of characters for phonebook names more number of SMS center „-“ missing SAT no separate broadcast control channel for each card work not with Siemens Sim_Emu 4.00 by Daniel „+“ easy to use SAT adapt number of SMS/Phone different broadcast control channel (?) power off no necessary work with Siemens „-“ only 14 characters for phonebook names only one SMS center for each card work not with old Panasonic (450/500) My metod for Sim_Emu 4.00: I use SIMedit 4.0 to write IMSI/Ki using SAT. No mistake with type when use clipboard |
![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002
Member: 10582 Status: Offline Thanks: 0
For wojtek
What is the SIMEdit 4.0 ?
Can you send me it ? (sim_emu@wanadoo.es) Thanks |
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2001
Member: 6156 Status: Offline Thanks: 0
The difference between SMSCs in my version and SIMEmu 4.0 is not the number because both have 8 SMSCs.
The difference is that SIMEmu has 8SMSc (one per active card) and does not allow to access the other 7... My version has the same 8, all available at any time and just changes the order depending on the selected card. I prefer this way because it accomplishes the same effect as having one SMSC per card with the "extra" that if you have less than 8 cards you can use their parameters to store different profiles, for instance, this was the setup I was using: Operator A Operator B Operator C Profile 1 -> Operator A, normal Text Profile 2 -> Operator B, normal Text Profile 3 -> Operator C, normal Text Profile 4 -> Operator A, fax Profile 5 -> Operator A, normal Text, but with only 1hour validity Profile 6 -> Operator B, fax Profile 7 -> Operator B, normal Text, but with only 1hour validity |
Yes and this is better for me.
I can use for any active card 3 SMSC by my Trium. And with Sim-Emu i have only one for active card. Last edited by wojtek; 04-08-2002 at 06:20. |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
Member: 3506 Status: Offline Thanks: 0
@wojtek
I have SIMEdit 4.0 but I cant used
![]() it cant find my Phoenix/SmartMouse interface can you help me? Last edited by masterross; 04-08-2002 at 03:47. |
Member: 10318 Status: Offline Thanks: 0
where can i get gsm_sim2c and Sim_Emu? Can somebody send me this files? thx .:[t-k4nzl3r]:. |
@t-k4nzl3r
read older topics
to masterross
I use SIMedit with ChipDrive reader.
#10 | |
Re: to masterross
masterross
Chipdrive is reader from Towitoko.
Connected to com port. SIMedit use PS/SC drivers. |
Member: 10850 Status: Offline Thanks: 0
I have question for Wojtek, so sorry that i'll write it in polish
![]() Wojtku, widzę że udzielasz się w temacie klonowania kart SIM i z przeczytanych postów wnioskuję, iż masz już niemałe doświadczenie... Mam do Ciebie jedno pytanko: czy próbowałeś wyciągnąć KI i IMSI z nowszych kart SIM-PLUS-a??? Podobno są z tym problemy.... dzięki z góry za odpowiedź! |
#13 | |
![]() ![]() ![]() Join Date: Feb 2002
Member: 9777 Status: Offline Thanks: 0
Re: „Gsm_sim2c“ versus „Sim_Emu 4.00“
![]() As i promised, i have tested SIM-EMU. Results below : - Siemens S45/ME45 with all providers. "Card Error" very often, impossible to use it normally instead of original SIM - Siemens S25 - works quite good, the card crashes much less often, but cannot change positions using SAT without powering off the phone - Siemens S35 - it also crashes very often and gettin' hangouts. Those phones were tested with all polish GSM providers. There was no problem with new Ericsson mobiles (t68, t39m), SIM-EMU works perfectly with erics. I am also gonna test it with several of Nokia phones later and give the results here. |
#14 | |
It is impossible to get KI key from a new PLUS GSM cards (called PLUS MEGA) at this time. Inaczej mówiąc - zapomnij na razie
For Milenko and Beerman
For the moment, I cannot reproduce the problems of Siemens in Poland, because all the models that I'd tried in Spain work perfectly with all our provider (Airtel, Amena and Movistar).
The models I had tried was S35i, C35 and S25. Did you obtain the same problems with 3.00 ? When I discover something about this, I'll notify immediately. Sorry and Thanks |
