![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 417298 Status: Offline Sonork: 100.1578269
a70 dead
i have a70 i run scenario and clik on {repair security{user imei 0000000000} set dead and not flah
error --- Reading Info--------------------------------------------------------------- User selected phone A70 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = AMD Am29LV320MH/L, size 4096 Kb Flash Chip = AMD Am29LV320MH/L, size 4096 Kb Phone ID = B82805D8 Flash IMEI = 356470-00-601562-3 Manufacturer ? Model ? Warning : Check phone model selection. Language ? Version ff Warning : EELITE is corrupted Warning : EEFULL is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Done. --- Loading Flash File--------------------------------------------------------- User selected phone A70 using Normal (Cut track) boot mode Loading A70_lg1_v13_356342003605624_0207-1309[1].fullflash. dtf"... Language : lg1 Done. --- Writing Flash-------------------------------------------------------------- User selected phone A70 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = AMD Am29LV320MH/L, size 4096 Kb Flash Chip = AMD Am29LV320MH/L, size 4096 Kb Phone ID = B82805D8 Flash IMEI = 356470-00-601562-3 Manufacturer ? Model ? Warning : Check phone model selection. Language ? Version ff Error : Please select correct model. Hint : Strict model validation is turned on Error : Failed. what can i do |
![]() ![]() ![]() Join Date: Sep 2004
Member: 81703 Status: Offline Thanks: 841
Did you try without Scenario?
BR Luskao |
a70 dead
yes i tried
Hello, mohsin-*!
Please, try to run Repair Security Data (Use IMEI from Flash OTP). |
--- Repareing------------------------------------------------------------------
User selected phone A70 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = AMD Am29LV320MH/L, size 4096 Kb Flash Chip = AMD Am29LV320MH/L, size 4096 Kb Phone ID = B82805D8 Flash IMEI = 356470-00-601598-3 Manufacturer ? Model ? Warning : Check phone model selection. Language ? Version ff Error : Please select correct model. Hint : Strict model validation is turned on Error : Failed. i do Repair Security Data but get uper message |
Maybe there is a problem with the selected model, I got A60 the other day with a case of C60 and did that error. Check that the model is the correct in the sticky under the battery
BR Luskao |
To mohsin-*
If you don't make mistake with a choice of model of the phone, please, send ALL log files from DBSS with your forum's name and problem description to us (Program Files->DreamBox ALL .log files).
