Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > GSMServer Products > DreamBox
Old 03-23-2007, 10:59   #1
@rtist1963
Member: 102387
Testpoint and power adapter cable.
Dreamsupporter, can you tell me what the voltage values are on the service cable when I use testpointcable with button?
Now I have ( plus from multimeter to power adapter and black on testpoint probe ) -3.5V When I push the button the value is -2.5V
Is this correct?
Old 03-23-2007, 14:08   #2
DreamSupporter
Member: 241271
Hello, @rtist1963!
Why did you use a button on the cable? It's not needed. For use testpoint:
1. Connect the phone. It must be turned OFF.
2. Connect testpoint connector to "+" on your phone.
3. Run an operation of DBSS which you need.
4. Connect the testpoint probe to the phone as shown on the picture and wait.
5. Disconnect the testpoint probe, when you will see a message about this.
Old 03-24-2007, 00:04   #3
@rtist1963
Member: 102387
It's the button that's inside the testpoint cable, not a loose button.
I want to unlock a Siemens A62 that must be unlocked with testpoint cable with button but it doesn't work. The pop-up for testpoint appears and when I place the probe nothing happens.
So I want to know what the voltage values are when the button is not pressed or pressed, because I have the feeling that the testpoint cable is faulty.
The testpoint probe without button works fine.
Old 03-24-2007, 16:02   #4
DreamSupporter
Member: 241271
Probably you need to modify your TP cable. Please, read here a manual "Testpoint cable EGold modification (PDF)".
Old 03-24-2007, 16:26   #5
@rtist1963
Member: 102387
The cable was already modified, but not working on A62.
The only question I have is that the voltage should drop to zero when I push the button?
Old 03-24-2007, 21:45   #6
c_ahmad79
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
brother some days ago i need to flash one a62 so i try with tp but unable to boot the phone
so wot i did i cut the track and then able to boot the phone i also have one question with dream box team
sir we still need to cut the track....????
so why i spend alot money on this dream box...?
if i still need to cut the track so i should use joker.....?
plz dream box team do some thing about these models..
thanks
Page generated in 0.06781 seconds with 6 queries
