Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > GSMServer Products > DreamBox
Old 03-30-2007, 15:51   #1
GSM Dream
GSM Dream's Avatar
Member: 214480
Exclamation DBSS v2.5
Dear users,
We are pleased to announce a release of new versions of DBSS v2.5.
This version offers the following new options:
  1. Battery calibration*;
  2. Key Manager (allows to add/edit/import keys manually);
  3. "Get info about box" option showing box data from the server;
  4. "Burn In Test"**;
  5. Corrected "Repair security" process;
  6. Improved "Scenario" procedure.
More features to come.
Best regards,
GSMDream team
DreamBox - Get more with it.
* This function is developed for automatic calibration of phone's battery settings after wrong flashing.
** By using this feature the phone settings can be set to the maximum values (maximum LCD backlight, vibration level, the speaker (buzzer) sound etc.), therefore the handset turns to maximum energy consumption.
Old 03-30-2007, 16:14   #2
mamirza
mamirza's Avatar
Member: 300540
DBSS v2.5
Good work, and nice improvements!
Pls keep it up.
Old 03-30-2007, 16:20   #3
phanthom2o4o
phanthom2o4o's Avatar
Member: 33736
Goos work... thanks for update
Old 03-30-2007, 16:21   #4
shawgsm
shawgsm's Avatar
Member: 51453
nice update mate
regards
Old 03-30-2007, 16:29   #5
luskao
Member: 81703
Good work, now we can do nearly everything with Siemens phones Thanks for this great update and keep as usual
Luskao
Old 03-30-2007, 16:30   #6
r_alex
r_alex's Avatar
Member: 243792
thanks for update ...
Old 03-30-2007, 16:38   #7
.::AZEEM::.
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanx For Update Sir ..................................
Old 03-30-2007, 16:43   #8
markali2006
Member: 245748
nice update
kicken again
Old 03-30-2007, 16:44   #9
c_ahmad79
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
thanks for the update...
keep up the good work..
Old 03-30-2007, 16:50   #10
ASHIF
ASHIF's Avatar
Member: 8353
Sonork: 113276
thanks for update........can u explain "Burn In Test"**;
Old 03-30-2007, 16:54   #11
GSM Dream
GSM Dream's Avatar
Member: 214480
By using this feature the phone settings can be set to the maximum values (maximum LCD backlight, vibration level, the speaker (buzzer) sound etc.), therefore the handset turns to maximum energy consumption. So you will be able to see what does not work
Old 03-30-2007, 17:39   #12
balu_dark
balu_dark's Avatar
Member: 16251
Good features for repair .I havnt this box but looks like good hardware for repair - no just for unlock like other!
Keep it up!
Old 03-30-2007, 18:02   #13
nirvanka
Member: 229780
Keep it up!
you are right! it's not just box for unlock you can write difference type of flashes, change language, repair IMEI, repair contrast.. and also there is very useful option - scenario for work with a lot of the same phones
Thanks DreamBox team for this update! i think option "calibrate battery" is very useful
Old 03-30-2007, 18:24   #14
dimon
Member: 7368
Key Manager do not work properly:
-- Calculating Keys for EL71-----------------------------------------------------------
User selected phone EL71 using Test Point boot mode
Warning : You should conect power to your phone
Model: C60 IMEI: 351948-00-0xxxxx-x
SKey (from Boot Hash) = [NOT FOUND]
Model: C65 IMEI: 354763-00-8xxxxx-x
Model: E71 IMEI: 351776-01-0xxxxx-x
Model: AX72 IMEI: 359229-00-1xxxxx-x
SKey (from Boot Hash) = 08388608
Warning : Aborted by user.
Old 03-30-2007, 19:11   #15
DreamSupporter
Member: 241271
@ dimon
Thanks for report! We will check if it is a bug or not .
Page generated in 0.09818 seconds with 6 queries
