Old 04-09-2007, 16:49   #1
The Gix
Member: 342556
BlueSoleil 3.2 for Vista Released
You can find it here: http://www.bluesoleil.com/download/i...soleil_voip_en
Old 04-09-2007, 17:03   #2
nishaon
nishaon's Avatar
Member: 225229
Thanks, but have anyone with no 5MB limitations or cracked?
Old 04-09-2007, 22:23   #3
shusan
Member: 365193
have any one its crack or patch?????????
Old 04-09-2007, 22:27   #4
DazzaMc
Member: 247605
I've heard that if you take the .exe from the download and over write the .exe of your current installed verson then you'll get around the 5mb problem.
Old 04-10-2007, 11:51   #5
shusan
Member: 365193
its not fully worked by ur exchanged system with .exe
Old 04-12-2007, 05:44   #6
JimmyZ
Member: 214950
i have a problem, what did the 5MB limit mean?
max file it can transfer?
total data transfer per session?
total data transfer per evaluation?
Old 04-12-2007, 08:40   #7
JimmyZ
Member: 214950
just tried, seems per session. not a big trouble...
Old 04-12-2007, 13:56   #8
mansour95
Member: 137890
please the crack
thanks!
Old 04-13-2007, 11:10   #9
m-tek1
Member: 137529
http://rapidshare.com/files/24496366/crack.rar
Try this seems to work o.k!!!
Old 04-13-2007, 11:44   #10
shusan
Member: 365193
At last i solve that problem for a long while. install BT 3.2.2.6 then replace with BT 2.1.3.0 exe (cracked exe)file. then go to tools , assign all ports for ur phone and see what happaning. I solved by this.
Old 04-13-2007, 15:20   #11
HonzaBouma
Member: 341535
Why do not you want to make crack for 3.2? I know, crack for 1,6.2 is probably working, but I should be pleased for the 3.2 version crack with all bug fix from previous versions...among others from 1.6.2
Old 04-14-2007, 21:58   #12
wlp5
Member: 264438
No offense, but replacing the exe from previous versions isn't really a crack. You're probably running the older edition with the new menus or something like that...
Old 04-15-2007, 10:37   #13
mansour95
Member: 137890
The only crack unfortunatley is 1.6.2 and some people say that this is the crack for 3.00 and 3.2
I and many people say that it does not work. In v3.00 when I open the transfer dialogue and send file it says: access denied.
So replacing the file is not a crack
We are waiting for the professionals to crack this program
please make a crack
Thank you very much
Old 04-20-2007, 08:22   #14
HonzaBouma
Member: 341535
Any news about crack?
Old 04-22-2007, 10:21   #15
netarchie
Member: 73523
waiting for the crack!!
[IMG] code is Off
Page generated in 0.09897 seconds with 7 queries
