![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 436006 Status: Offline Thanks: 0
What's next model you are looking for update in ET-BoX ???
Dear customers,
Please post here what is more important and usefull update you are looking for in ET-BoX. So that we can add those models in next following versions of ET-BoX. Br. ET-BoX Team ps. right now we are looking for requests from indian market only!! |
| The Following 4 Users Say Thank You to .:ET-BoX.net:. For This Useful Post: |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006
Member: 269044 Status: Offline Thanks: 8
i Want to know that will ET-BOX be adding Db2020 UNLOCKING in there box????
Can anybody help me to unlock W355 & F3c?
I need w355 & F3c Unicom firmware, pls help Thanks |
| The Following User Says Thank You to .:ET-BoX.net:. For This Useful Post: |
![]() ![]() ![]() Join Date: Dec 2006
Member: 406409 Status: Offline Thanks: 0
i want to know that will et-box be add a moto f-3 unlocking in this box ?
and thanks for adding a s540 in et-box |
ever one wants too know what ET-bx is doing next?????
![]() ![]() ![]() ![]() Join Date: Oct 2004
Member: 84807 Status: Offline Thanks: 20
zte cdma :
classic 201/202 classic 101 classic 231 add these model in ET user unlocking & flashing for .......... |
Member: 441477 Status: Offline Thanks: 8
Qualcomm LG 890/300/310/830/400/500/970
ZTE F866 Momodesign Md-1 |
need samsung c 140 and c140i in ET-BOX list
| The Following User Says Thank You to sahil2000ind For This Useful Post: |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 238812 Status: Offline Thanks: 125
Following is the software improvements required:
1. User should not be able to disconnect port without stopping current process, ESC key between flashing could disconnect port in your latest version. It may create problem. 2. Why should we disconnect phone when phone was not successfully connected or boot loader doesn't load? CONNECT button should again become CONNECT not DISCONNECT after a failed connection 3. Open File dialog box should have right click facility as in Explorer. We need (as I think) the following handset supported: 1. BenQ-Siemens A70 (Aircel) 2. Sagem Series (Hutch) After all, ET-BoX is great, I am very happy with it. Could you please provide SPECIAL BIRD Cable diagram? I promise I will never ask you know-how and create problem for you. If I can make this cable I will do that, If not, I will purchase but will never ask you silly questions like 'this connection is not working', 'how to solder', where to find connector' etc. Thanking you....
| The Following User Says Thank You to shadab_a4u For This Useful Post: |
#14 | |
i will answer you here. 1. you can stop any operation in case of emmergency, or you made any operation by mistake. but in 99% of cases you wont have any problem with boot area while flashing stopped is between with ET-BoX. 2. this cannot be modified due to many reasons. one is that each model needs different times and different tries in connecting with software. most other reasons are because of internal r&d procedures. 3. this can be corrected in next releases ![]() 4. about sagem handsets. i am not sure if this could be implemented. cause sagems need a special or a LPT interface to work. Br. ET-BoX Team |
#15 | |
Regards.
