Old 05-18-2007, 17:10   #1 (permalink)
Member: 175311
7610 buttons problem
the Select, back and down button doesnt work on my phone. they dont respond even if i press them hard and i've brought it to a shop where they have changed the keyboard for the keypad. it still didnt work and i went to a phone repair stall and they said flashing it could be the answer. would flashing fix it? what equipment/box/cable do i need to flash or is there any other way to fix it?
Old 05-19-2007, 01:07   #2 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
check two keypad ics, connector and finally upp.
Old 05-19-2007, 01:37   #3 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Its a HW problem,if the 2 Keypad IC swere replace so UPP is defective.
Old 05-19-2007, 10:09   #4 (permalink)
Member: 175311
I dont know what the ICS or upp is, so flashing the phone wouldnt work?
Old 05-19-2007, 12:35   #5 (permalink)
inamullah's Avatar
Member: 407178
Thanks Meter: 22
check two keypad ics, connector and change 100% ics problem
Old 05-19-2007, 12:47   #6 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
Hi m8t check this solution and very helpfull sol..........!
...:::Mr Fone:::...
The Following User Says Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 05-19-2007, 14:51   #7 (permalink)
bpcentergtk's Avatar
Member: 311436
Thanks Meter: 38
change this two keypad ic hundred % it will work
The Following User Says Thank You to bpcentergtk For This Useful Post:
Old 06-15-2007, 15:40   #8 (permalink)
Member: 279067
Thanks Meter: 9
Thanks MR_FONE you are very helpful to me................................................ .......................................
Old 06-15-2007, 23:32   #9 (permalink)
Member: 122774
Thanks Meter: 15
Nice pic!!
Very usefull
Old 06-15-2007, 23:39   #10 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
rehot keypad ic & if dosen't work change it & u r key ll work after
LordMen007
Old 02-28-2009, 09:34   #11 (permalink)
Member: 926051
Sonork: Blind
Thanks Meter: 5
I have the same whith key up. any one will help me plzzzz !!11111
Old 04-07-2009, 16:01   #12 (permalink)
Member: 680291
Thanks Meter: 21
hebrow i have same proablem but with left key
Old 04-07-2009, 17:52   #13 (permalink)
Member: 736655
Thanks Meter: 123
7610 buttons problem chinkzsta WD2 & APE (Symbian Phones) 11 06-23-2007 02:01
M35i buttons problem janwillemmac Siemens Hardware Repair Area 3 02-07-2004 19:18
cannot see edit button problem ryanhart Board, Server and Login Problems/Support 0 01-28-2004 04:11
8310 button problem thecult Nokia Digital Core Technology 4 ( DCT-4 ) 1 05-09-2003 14:56
8310 button problem Cosmar Nokia Hardware & Hardware Repair 0 08-28-2002 12:40
Page generated in 0.26785 seconds with 10 queries
