![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 436006 Status: Offline Thanks: 0
ET-BoX - v1.38 Released - Spice S410 Full Support Added
June 5th 2007 - v1.38 Released
# Added full support for Spice S410 Br. ET-BoX Team |
![]() ![]() ![]() ![]() Join Date: Apr 2003
Member: 25759 Status: Offline Thanks: 0
Tested and working 100% revived a dead set killed by infinity
and no more AIRTEL LOGO after flash Flash ID : 017E1A01 Flash type : AMD - 4Mb ---------------------------------------------------------- Writing flash from file : SPICE S410_full.crf ---------------------------------------------------------- Checking flash file ... OK Writing flash ... OK ======== Process completed ======== Operation time - 05:24 ---------------------------------------------------------- Unlocking ... Checking locks area ... OK Making backup file : Reading eeprom area ... OK Saving flash ... OK Backup saved to file : SPICE S410_KACS410_INA_EN_HI_4_02_330_2007_6_5_16_16_bkp .crf Writing eeprom area ... OK ======== Process completed ======== Operation time - 01:43 |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 242626 Status: Offline Thanks: 0
Good update keep It Up
![]() ![]() ![]() Join Date: Jan 2005
Member: 110102 Status: Offline Sonork: 100.1580399
nice works et-box team
Member: 368546 Status: Offline Thanks: 285
actually some of the set unlocked in infinity didi not worked but in et 1000% perfect
![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 121100 Status: Offline Thanks: 26
Good update............................................ ...
#7 | |
Thnx for the log. but might you are using too slow speed to flash, thats why took 5 mins in flashing. with fast speed it just takes less than a min to fully flash the phone ![]() Br ET-BoX Team |
![]() ![]() ![]() ![]() Join Date: Jan 2004
Member: 48238 Status: Offline Thanks: 9
Nice Gift for Indian Users.
Gr8 work from you as well as your entaire teem. @ Sujyot Gsm India |
![]() ![]() ![]() ![]() Join Date: Jul 2006
Member: 308822 Status: Offline Thanks: 25
nice update keep it up et box team
Member: 51132 Status: Offline Thanks: 145
great update keep it up et team..
#11 | |
Member: 130995 Status: Offline Thanks: 4,418
Don't you think that you a "little bit" wrong in your words ? If you had a problems with S410 why you did not contacted to me with the problem ? So, the truth is: you write something just to write something and it's really bad way fo you to make your own reputation. @roshantelecom&s the same to you |
@ All
As i have made instructions earlier also. We dont want to compare our product with any other product in market. Whether it be a positive or a negative comparision. Please take care of this note in future!! @ A1 Cell Solution posible reply from you could come like this in future: "Tested and working 100% revived a dead set killed by other tool" @ InfinitySupport you know i respect you and your team a lot. but similarly you could see hundreds of posts under "infinity support section" where people compare products. Br. ET-BoX Team |
![]() Join Date: Dec 2004
Member: 99609 Status: Offline Thanks: 11
Thanx for updates
nice updates keep it up
#14 | |
![]() ![]() ![]() ![]() Join Date: May 2005
Member: 143281 Status: Offline Thanks: 32
We are the users and the choosers. We can can compare anything, anywhere. We have to know that every box can kill each supported phones, sometimes we can revive from the same box and sometimes we have to revive from other boxes. The best is not to depend on only one box, try to have different boxes as much as u can. FYI: Anyway i owned Smartclip, ET-Box and Infinity Box, the truth is; if all support the same phone, I always used ET-Box. I used other Boxes only if ET-Box dont support that phone, cos i'm the chooser.
ET-BoX can now unlock all versions of Spice S410. If you are not able to unlock with Direct Unlock option, then please flash the phone with "SPICE S410_fw.crf" found in the support area to unlock 100% any version.
Just takes less than 90 seconds. Br ET-BoX Team |
