Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > ET-BoX
Old 06-14-2007, 13:04   #1
manish665
Member: 170587
how to flash c117 & where is TP of c117
plz help me sir for this reason
Old 06-14-2007, 13:32   #2
.:ET-BoX.net:.
Member: 436006
1. Open phone and cut track according to picture in Pinouts Folder.
2. Run ET-BoX Latest Version and select com port and press "Connect"
3. Select Phone Model
4. In connection Options, Select "Connect with Cut Track"
5. Press "Connect Phone".
6. Connect Cable to Phone and press power on.
7. Select corresponding flash file and then flash the phone.
8. Disconnect the phone and then restore the track.
9. Phone should be OK
Br.
ET-BoX
Old 06-14-2007, 14:49   #3
manish665
Member: 170587
i got error messege when flash file select
sir i got error mess. that is bad file flashes type selected. plz help me i m new user for ET-BOX.
Old 06-14-2007, 19:59   #4
sahil2000ind
sahil2000ind's Avatar
Member: 269044
Br.
ET-BoX
THANKS SIR FOR URE POST
Old 06-15-2007, 10:34   #5
.:ET-BoX.net:.
Member: 436006
please explain your error a bit more. cause if i dont understand where you are having problem. i cannot help you exactly
ET-BoX Team
Old 07-11-2007, 21:15   #6
sahil2000ind
Member: 269044
Arrow
Br.
ET-BoX
ET-BOX TEAM IF WE CUT THE TRACK HOW CAN WE RESTORE THE TRACK NO ONE IN THIS WORLD CAN RESTORE THE TRACK.. IF WE HAVE THE TEST POINT..
IF U HAVE ANY SOLUTION PLS TELL US ALL
Old 07-12-2007, 10:05   #7
.:ET-BoX.net:.
Member: 436006
i think you have not yet tried to cut any track till now. cause its very easy to cut the track and then restore it.
well, if you dont have knowledge for hardware then its better you get it done from someone else.
ET-BoX Team
Old 07-12-2007, 17:50   #8
sahil2000ind
Member: 269044
ET-BoX Team
SIR ITS A VERY KIND OF U THAT U REPLIED TO MY POST.
SIR I HAVE UNLOCKED MORE THAN 800 MOTOROLA WHICH WERE COMMING WITH AIRTEL AND IDEA WITH THERE CONNECTIONS.. MANY WERE DONE WITHOUT ANY THING AND FOR SOME WHICH GOT DEAD WERE DONE WITH CUT TRACK...
Old 09-11-2008, 19:50   #9
valtea
Member: 380109
i think the same applies to C139. DO we need to connect battery during the flashing with cut track?
Old 09-12-2008, 08:52   #10
nonu_don
nonu_don's Avatar
Member: 22538
yes, u need to connect battery as normal.
Naman
Old 10-22-2008, 23:21   #11
sekharsun28
Member: 462076
Sonork: 100.1586314
can u give us track
sir can u give us track
Old 10-25-2008, 04:17   #12
sekharsun28
Member: 462076
Sonork: 100.1586314
sir i am unable to connect motorola c117 in normal mode..its not not responding when we press power on..i am using com1...help me
Old 10-25-2008, 04:18   #13
sekharsun28
Member: 462076
Sonork: 100.1586314
i am eagerly waiting for ur reply..respond fast..
Old 10-25-2008, 10:44   #14
nonu_don
nonu_don's Avatar
Member: 22538
what problem in phone?
is the phone dead or on? and what error are you getting while connecting it to ET-BoX.
please explain a bit, then only i can help.
Br.
Naman
Page generated in 0.11538 seconds with 6 queries
