Old 07-04-2007, 00:41   #1
ThaRaptor
Member: 539431
Logitech Bluethoothub
Hi
I have and bluethoothub for Logitech Media Desktop mous and keyboard that before I could hoock up with my mobile and all other bluetooth units with widcomm software. I have now reinnstaled my whole computer, incluuding the set point software for the keyboard and mise with the bluetooth hub.
Then I saw that the widcomm software wasent instaled ! I coulden hook my phonu up with the computer anymore! So after 5 houers serching for the Widcomm driver I found it, v.5.0.1, but it wont "detect the bluethoot hub" so I cant connect tomy phone. any1 have any ides ?
~Rap
Old 07-09-2007, 01:15   #2
jakubd
Member: 157219
Please be more specific about Logitech device: there are 2 different devices with Bluetooth that fit this description, that use different BT Hubs (DiNovo uses old type BT adapter integrated with mouse charger, Laser version uses USB stick with button).
Your problem is connected with wrong sequence of installation: you should follow the procedure from documentation step after step - usually you have to start installation and connect BT Hub only when asked to. If you use correct version of SetPoint installation set (the big one, sth like 50MB) it contains Widcomm drivers and should install BT stack.
There was some information on Logitech forums and support webpages about correct method of installation of BT devices - you have to look for it.
Old 07-17-2007, 04:56   #3
ThaRaptor
Member: 539431
Thanks for the info.
The Hub is the type where you can put your mice down and load it....
~ThaRaptor
Old 07-18-2007, 12:22   #4
ngvuanh
Member: 112657
You have to download and install Setpoint for BT from Logitech. It will enable hub as BT device and install its driver. After that, you can install widcomm or other BT software.
[IMG] code is Off
Page generated in 0.07303 seconds with 6 queries
