![]() ![]() ![]() Join Date: Aug 2005
Member: 171342 Status: Offline Thanks: 1
c140
pls added some samsung models come with airtel like c140 & others
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 436006 Status: Offline Thanks: 0
![]() ![]() ![]() ![]() Join Date: May 2005
Member: 143281 Status: Offline Thanks: 32
I think adding Samsung C140 is a must! 'coz so many user request this model to support in ET-Box.
Lets hope ET-Box Team will not fail and it will be added soon... very very soon |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004
Member: 100592 Status: Offline Thanks: 33
thanks ET-BOX
best of luck & Best Regards GSMCrazy1 |
![]() ![]() Join Date: Jun 2007
Member: 535478 Status: Offline Thanks: 1
when will be added samsung c 140 Unlocking in et-box.
we are waiting for that. |
Member: 22538 Status: Offline Thanks: 1
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006
Member: 269044 Status: Offline Thanks: 8
09/07/07 - ET-BoX v1.45 Released - Samsung C140, C140i Added with Full Support!!
July 9th 2007 - v1.45 Released * Added New Brand Samsung Tab * Full Support Added for Samsung C140, C140i Supported Features: * Read Flash * Write Flash * Unlock * Read Codes * Reset Phone (MMS, Media, Stack, WAP, NVM, JAVA, etc) * Repair IMEI Instructions for Unlocking Airtel Handsets: 1. Open ET-BoX v1.45, Select Samsung Tab, Select Samsung C140, Connect Port 2. In "Connection Options" select "Flash Mode Connection" and press "Connect Phone" 3. Press Power button on phone. 4. Go to Flasher Tab & Select any of the flash file available in Support area. 5. Flash the phone. 6. Press Disconnect phone, Re-insert the cable in Samsung C140 and power on the phone. 7. Now change setting in "Connection Option" to "Test Mode Connection" and again press "Connect Phone" 8. Press "Direct Unlock" & Disconnect Phone. Complete Procedure for Unlocking Airtel Handsets Take Apprx 3 Mins to 4 Mins ONLY!! Br. ET-BoX Team |
![]() ![]() ![]() ![]() Join Date: Jan 2004
Member: 48238 Status: Offline Thanks: 9
![]() ![]() ![]() ![]() Join Date: Jul 2004
Member: 73479 Status: Offline Sonork: 100.1581683
c140
which cable do i use .................pls
