#17 |
Member: 234396 Status: Offline Thanks: 3
#18 |
Listed Cheater
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 575900 Status: Offline Thanks: 654
tha nks bro its good work verry verry thanks my fone 100000000%ok
#19 |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2003
Member: 40602 Status: Offline Thanks: 53
can i use infinity to flash this file: BPLGUInfoCustomSrcP_KG200P64-91-V10c-XXX-XX SEP 27 2006
?? coz i hard to connect with devin tool. br, s1emens |
#20 |
i always having error connecting handset: 27, but if connect with infinity ok
br, s1emens |
#21 | |
Member: 64311 Status: Offline Thanks: 11
....you can also cut your infinity RJ45 cable and can convert it to serial...everything is up to logic and good workREGARDS |
#22 |
about error 27
when we press connect, do we have to press power? or i turned on the phone? br, s1emens |
#23 | |
If your sure about your cable is all perfact then your procedure must be wrong.... 1. keep handset switch off 2. attach cable to phone through comport 3. then press connnect in devin tool 4. only after pressing connect button keep pressing on/off button till it show handset connected 5.after handset connected brows for reset file 6. select reset file 7. after reset file initialize successfully reset every thing |
#24 |
![]() ![]() Join Date: Jul 2007
Member: 545566 Status: Offline Thanks: 20
Helo ;
Rocky hru its great help brother keeeeep it up . thanks .................. wazir |
#25 | |
THANKS let me try it once more, let u know the result. br, s1emens |
#26 |
![]() ![]() ![]() ![]() Join Date: Apr 2005
Member: 136173 Status: Offline Sonork: 1581759:111
need kg300 file
sir file which u uploaded is for kg200 but the file which i need is for kg 300 please help
#27 |
oooops
#28 | |
for kg 300 using deven tool thanks i am waiting for your reply .............. wazir |
#29 |
@wazir and everyone who dont know how to make it
Dear Friends still few forum members and others not undersand how to make self made cable.......i have been making cable by my self and posted manytimes in forums too...again posting the detail how one can make their desirable cable using RS232(Serial cable,9pin).
First rerer to the pic attached and carefuly read the description. Pin No. Name Dir Notes/Description 1 DCD IN Data Carrier Detect. Raised by DCE when modem synchronized. 2 RD IN Receive Data (a.k.a RxD, Rx). Arriving data from DCE. 3 TD OUT Transmit Data (a.k.a TxD, Tx). Sending data from DTE. 4 DTR OUT Data Terminal Ready. Raised by DTE when powered on. In auto-answer mode raised only when RI arrives from DCE. 5 SGND - Ground 6 DSR IN Data Set Ready. Raised by DCE to indicate ready. 7 RTS OUT Request To Send. Raised by DTE when it wishes to send. Expects CTS from DCE. 8 CTS OUT Clear To Send. Raised by DCE in response to RTS from DTE. 9 RI IN Ring Indicator. Set when incoming ring detected - used for auto-answer application. DTE raised DTR to answer. So ultimately in simple term pin 2 is (Rx),pin 3 (Tx),pin 5(GND) in rs232 cable. Having rx,tx and gnd is enough for cellphones. |
#30 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 391445 Status: Offline Sonork: 100.1583575
will this work for KG200 as well??????/
kindly post reply as soon as possible i have 3 Kg200 that shuts down automatically br |
| The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post: |
