Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > LG > LG Hardware Repair Section
Old 09-08-2007, 12:41   #31
StRaNgE PeRsOn
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
thnx 4 that,and tell me will this work for KG200 as well?
br
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 09-08-2007, 16:49   #32
i_am_rocky
i_am_rocky's Avatar
Member: 64311
YES also work with kg200
Old 09-08-2007, 18:22   #33
irfan99
irfan99's Avatar
Member: 242264
Sonork: 100.1582011
if
if u are quit quick then u dont need this software start phone and put this code 2945#*# and format phone it will work i did a phone with this
Old 09-10-2007, 17:23   #34
neb
Member: 751
Just repaired a KG300 with auto shutoff problem using Devin Tool and KG300 reset file.
Old 09-25-2007, 04:24   #35
faithless gsm
Member: 65294
haha i kicked it out !!! just be sooo fast and type 2945#*# then up arrow to reach the format NVRAM command then o.k ! u will need to do that several times to catch it up coz once u click o.k on format NVRAM the fone will start formatting and will not restart tested and worked 100%
Old 10-12-2007, 13:09   #36
st_mobile
Member: 518819
urgent
i have cable g50 for uni box how to use thiis cable for kg300
Old 10-12-2007, 13:12   #37
st_mobile
Member: 518819
Originally Posted by sant View Post
good work 100%tasted
thanks
sant
which cable have u use and how to make
Old 10-13-2007, 12:56   #38
NADEEM GONDAL
Listed Cheater
Member: 575900
thanks but fone is connected many time try after succes.........so i use infinty it very very best just click on format on ffs the fone is 1000000000%ok infinty is the great
Old 12-04-2007, 20:31   #39
odayking
Member: 116176
i used devil tool and coonect phone see (connect) then upload rest file but rest option still not active
whats problem pls
Old 12-06-2007, 22:45   #40
communication_expert
communication_expert's Avatar
Member: 50511
Question KG200 Restart...?
when i am kg200 mobile phone camera on then mobile is restart....
i am doing full flash but have a still problem and going to video mode mobile is hang what should i do ............?????
Old 12-06-2007, 22:52   #41
.:==di@bila==:.
.:==di@bila==:.'s Avatar
Member: 254137
I alway solve KG300 restart problem by formating FFS via Infintiy.
The Following User Says Thank You to .:==di@bila==:. For This Useful Post:
Old 12-12-2007, 07:54   #42
astana2007
astana2007's Avatar
Member: 285345
This is for those who need it.i have been lookin still many peoples not able to set this problem..this thread for those peoples.
KG300 auto off solution
1. download devin too attached
2. download special reset file attached.
3 download flash file attached.
4 download flash software attached.
5. cable pinout attached.
6. connect handset in devin tool..when connect select reset file and reset bluetooth,security,and phone reset etc.
7.only after reset your phone will be all ok...but its better to full flash.
8. full flash using any professional software or using leo.
9 after full flash 2945#*# and do factory reset.
10. ENJOY
Regards
Sir can u tell me that which cable we will use with this software com cable or USB or any other cable like RJ45
and also want to know that is it a crack software or we will need a box to use it
Old 12-12-2007, 08:19   #43
i_am_rocky
i_am_rocky's Avatar
Member: 64311
@astana
you can use any self made cable...usb or com dosent matter..only be specific in proper pinouts...this software dosent require anybox feel free to use it.
Old 12-31-2007, 06:53   #44
Rahimamir786
Member: 664932
listen bro can u pls send me the flashing software that u used and describe the cables that are required.
Old 01-28-2008, 19:32   #45
dozhosting
Member: 691597
thank you so match, and i hop if i can help you in the future
Page generated in 0.11595 seconds with 7 queries
