Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > LG > LG Hardware Repair Section
Old 06-16-2008, 22:42   #61
khokonhajigonj
khokonhajigonj's Avatar
Member: 771795
Sonork: 771795
I am rocky
Boss i am sorry this is my misstake. my kg 300 data cable input connector pin out 4rm pcb.. So i want pcb rx,tx,ground pic. pls. help me one time again. I am so sorry 4r my misstake.................................
Old 06-17-2008, 08:34   #62
khokonhajigonj
Member: 771795
Sonork: 771795
KG-300 pin out 4rm pcb
Attach picture........................................... ......
Old 06-17-2008, 19:19   #63
i_am_rocky
i_am_rocky's Avatar
Member: 64311
get it from here http://www.MegaShare.com/431666
i made this cable by cutting motorola charger
The Following 2 Users Say Thank You to i_am_rocky For This Useful Post:
Old 06-18-2008, 20:07   #64
Hariadi Lianto
Member: 525906
Thumbs up Good work
Originally Posted by faithless gsm View Post
haha i kicked it out !!! just be sooo fast and type 2945#*# then up arrow to reach the format NVRAM command then o.k ! u will need to do that several times to catch it up coz once u click o.k on format NVRAM the fone will start formatting and will not restart tested and worked 100%
This is the best solutions!
Special Thanks for faithless gsm
Old 06-23-2008, 14:42   #65
614270
Member: 715659
hi ser ato oof poroblam betry lose and conector lose and dust ower charging jac
Old 08-11-2008, 19:38   #66
kk_vsam
Member: 619828
which cable can use?
can I use mini usb cable
Old 08-18-2008, 11:30   #67
kk_vsam
Member: 619828
Originally Posted by i_am_rocky View Post
This is for those who need it.i have been lookin still many peoples not able to set this problem..this thread for those peoples.
KG300 auto off solution
1. download devin too attached
2. download special reset file attached.
3 download flash file attached.
4 download flash software attached.
5. cable pinout attached.
6. connect handset in devin tool..when connect select reset file and reset bluetooth,security,and phone reset etc.
7.only after reset your phone will be all ok...but its better to full flash.
8. full flash using any professional software or using leo.
9 after full flash 2945#*# and do factory reset.
10. ENJOY
Regards
Sir my kg300 have same fault Auto off.so i use devin tool
Devin tool say "Error in connecting Handset :27"
I use self made cable .mini usb cable to serial port
i use correct pin settings.
So whats the problem?need any drivers?
Thanks in advance
Old 09-02-2008, 12:01   #68
cell2cellphone
Member: 450906
hello dear i have a lg kg200 with cmera problem can any body help me,......................................,m,,,,,,, ,,,,,,,,,,,,,,,thnx
Old 09-06-2008, 07:07   #69
LankaGsm
Member: 846111
kg300 auto off solution l think it's the best way if u don't have infinity.. press on key wait till it on and turned off, push 2-3 times the on/off key shortly again, now it gonna on for a while. then press 2945#*# quickly and select factory reset gonna be all ok ..
Old 09-06-2008, 17:05   #70
imran555
Member: 749733
hi to all just format with INIFINTY BOX problmis solvd
Old 09-21-2008, 11:59   #71
imran_alialmani
Member: 860369
hello/ sir i have kg200 . it shows batery temprature over limit during conect the charger/if any one have solution just post that .thankx
Old 09-21-2008, 13:50   #72
alamgarh
alamgarh's Avatar
Member: 358694
Originally Posted by faizan15 View Post
hello ur link not working, Please upload it on MEGASHARE or any other server without RAPIDSHARE, also i need reset file.
Old 09-23-2008, 21:47   #73
clinx
Member: 572191
Originally Posted by odayking View Post
i used devil tool and coonect phone see (connect) then upload rest file but rest option still not active
whats problem pls
mr rocky, thx for solution. i have some problem like odayking. reset buttom not active. please give me the solution
Old 12-21-2008, 17:35   #74
Raa_z
Raa_z's Avatar
Member: 471777
Arrow Lg kg 300.
hello,
I have a Lg kg 300.there is a problem 4 5 6 not working,is any body help me.
Old 01-05-2009, 23:02   #75
kava
Member: 210669
reset it with infinity
Page generated in 0.10635 seconds with 7 queries
