Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > SonyEricsson > SonyEricsson
SonyEricsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • Reply
    Old 08-22-2007, 10:30   #1
    reactos
    reactos's Avatar
    Member: 323137
    New Setool2 Lite v1.07
    v 1.07
    - now working with DB2012 CID50/51 phones.
    FREE flashing, FREE files WRITE, FREE GDFS read/write.
    - NO .VKP, NO FILES READ, NO CROSS-CID FLASH
    - now file in misc.edit during flash procedure first treated as package,
    if it not recognized as package, it treated as script.
    - added db2020 usercode reset (because gbrooks sniffed out
    string "06 89 01 01 00 0D 8B", GJ, gbrooks )
    download http://www.savefile.com/files/992021
    more info about setool2 lite here http://forums.se-nse.net/index.php?showtopic=13115
    Old 08-22-2007, 11:18   #2
    gprsman
    Member: 217461
    Unlock/repair button?
    Old 08-22-2007, 11:28   #3
    shahzaadbutt
    shahzaadbutt's Avatar
    Member: 123458
    Sonork: 100.1579636
    only free flasher not unlock
    Old 08-22-2007, 11:41   #4
    reactos
    reactos's Avatar
    Member: 323137
    unlock repair is for reading security code on phone
    Old 08-22-2007, 12:49   #5
    diocles
    Member: 25334
    Hi All !
    try to flash my k750 and i always get this message:
    welcome to setool2 lite edition v 1.07
    supported DB2010/DB2012 CID49/50/51, DB2020 CID49/51/52
    Loaded 51 flash descriptors
    ChipID:8040,EMP protocol:0301
    PHONE IS BROWN
    FLASH CID detected:49
    Speed:921600
    Flash ID check:890D
    Flash props sent ok
    OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxx CERT:BROWN
    FLASH CID:49 COLOR:BROWN
    MAPP CXC article: R1CA021 prgCXC125952_EU_1_CL
    MAPP CXC version: R1CA021
    Language Package:TMO_INT_D
    CDA article: CDA102338/146
    CDA version: R3A
    Default article: cxc125953
    Default version: R1DA003
    Network LOCKED
    Operator: 216-30
    USERCODE:0000
    Elapsed:4 secs.
    PHONE IS BROWN
    skipping empty loader...
    phone pre-boot failed,possible RECOVERY needed.
    Elapsed:22 secs.
    what is the problem
    sorry my bad english
    Old 08-22-2007, 13:18   #6
    LBOZ_GSM
    Member: 300043
    woohoo... finally i removed usercode on k550i
    ChipID:9900,EMP protocol:0301
    PHONE IS RED RETAIL PRODUCT
    FLASH CID detected:51
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:51 PAF:1 IMEI:35489301552999 CERT:RED
    FLASH CID:51 COLOR:RED
    MAPP CXC article: R1JD001     prgCXC1250669_GENERIC_LI
    MAPP CXC version: R1JD001
    Language Package:EUROPE_2
    CDA article: CDA102743/101
    CDA version: R1A
    Default article: cxc1250671
    Default version: R1JD001
    Operator: 000-00
    Elapsed:11 secs.
    Speed:921600
    LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    Flash ID check:897E
    Flash props sent ok
    CSloader version:
    070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009
    loader startup: executed
    loader GDFS startup: executed
    USERCODE reset to 0000
    Elapsed:23 secs.
    Old 08-22-2007, 13:23   #7
    Aishur
    Aishur's Avatar
    Member: 28188
    Originally Posted by diocles View Post
    Hi All !
    PHONE IS BROWN
    Speed:921600
    Flash ID check:890D
    Flash props sent ok
    To use this tool, you will need a basic knowledge and skills
    IF YOU EVER ENCOUNTER BROWN CID49 phone with LOCKED OTP
    OTP LOCKED:1 CID:49 PAF:1 IMEI:359061000XXXXX CERT:BROWN
    ****NOTE! IF YOU NOT MAKE IT - YOU WILL KILL PHONE FOREVER!!!!!!!
    you MUST do following:
    1.Go to Settings tab, UNCHECK "revert to red"
    2.Back to Semc tab, CID CHANGE=current
    3.Add in firmware tab: for K750/W700 - eroms\w700red_erom.ssw.cry for w810/z530/k310/k510/z550 - eroms\w810_erom_red49.cry
    4. Press flash. Retail EROM will be written and you can service phone as usual. ****What we MUST know about CID:49 phones****
    4
    It is not possible to do it with this free tool
    Best regards
    Old 08-22-2007, 13:58   #8
    CxVj
    CxVj's Avatar
    Member: 122712
    setool2lite v1.07 unlock usercode free omg thanks the_laser for this tools
    Old 08-23-2007, 05:34   #9
    aashir
    Member: 50772
    Which Flash File Using For This Software
    Old 08-23-2007, 06:36   #10
    CxVj
    CxVj's Avatar
    Member: 122712
    flash file also same as setool2g dongle box the format file is .ssw
    CMIIW
    Old 08-23-2007, 07:12   #11
    7777
    Member: 542009
    how to sir?i have 1 user code from S500I (CID52 RED)
    Thanks
    Old 08-23-2007, 07:25   #12
    CxVj
    CxVj's Avatar
    Member: 122712
    Thanks
    only support at this list CMIIW
    Old 08-23-2007, 09:24   #13
    aashir
    Member: 50772
    CMIIW
    sir any link for flash file
    Old 08-23-2007, 17:31   #14
    Aishur
    Aishur's Avatar
    Member: 28188
    Setool lite can't load *.ssw,*.cry setool firmware.
    The supported extensions are mbn, fbn,bin (Original firmwares) and when setool lite sees a valid file, It wil says what CID the file is for
    A huge collection is a topsony.com
    Best regards
    Old 08-23-2007, 19:01   #15
    elkawasmy
    elkawasmy's Avatar
    Member: 113200
    Sonork: 100.1573773
    Tnx For Sharing Brother..
    Page generated in 0.12150 seconds with 7 queries
