Member: 156819 Status: Offline Thanks: 0
Bluetooth two simultaneous connections
I have a MSI Btoes 2.0, the BlueSoleil version
![]() I want to use a Logitech V270 mouse and simultaneously connect using a bluetooth serial port to my phone, a SE P900. The problem is, when the mouse is in use, the serial port connection doesn't work (unknown error), and when the serial port connection is open, the mouse does not connect. It's frustrating!!! I tried Widcomm 5.1.0.1100 hacked, blue soleil 1.6 that came with the MSI, Blue Soleil 3.2 and 5.0. Is there a way to use them both at the same time ? I am starting to doubt it's even possible with Bluetooth ... PS: What I liked about Widcomm is that it installs HID as a system service, the mouse works in the login screen too ... but it has an annoying lag if you leave the mouse untouched ... the lag is much lower using BlueSoleil and the tracking of the mouse is much better also ... just a heads up
anyone? is it possible to use a serial port and a HID connection at the same time?
![]() Join Date: Jun 2007
Member: 521912 Status: Offline Thanks: 0
I had not problem when using both a serial port (gps adapter connected) and a HID connection (mouse and keyboard Logitech MX700) at the same time using Widcomm 5.0.1.2703 caused the elder Logitech BT software
