![]() ![]() ![]() ![]() Join Date: Feb 2001
Member: 3309 Status: Offline Thanks: 0
I have 12 this phone with alike defect !!!!
Network search 100% , But no possibility to do outgoinging call or take call !! I try : 1. repare flash 2. change Motorola Asic; Rx frontend (LNA) 3. change 13MHz crystal ![]() 4. change External antenna connector with switch Nothing did not help - defect remain on former! Any solution !!! P.S. : possible, it is necessary to change - Semiconductor MC33170; RF Amplifier (but I not have this chip) |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2001
Member: 5019 Status: Offline Sonork: 100.110196
Contact me private
Contact me for fast,easy,100% working solution!
For All !!
Thank you ARC !
I need other solution ! |
![]() ![]() ![]() ![]() ![]() Join Date: Aug 2001
Member: 5569 Status: Offline Thanks: 0
some time file eeprom in your phone is bad [sw repair by Vygis V 1.2]
try any more |
Hi OWN !
I try Vygis (30zone) and Mcomm Repairer (50 - 80 zone) Nothing does not help!! I talk with Vygis and it has said me that this SWrepairer can help only for that telephones which freeze or restart or do not see any network ! I think this Hardware problem! But exactly this knows ARC - can it will say us about this ??
Member: 7250 Status: Offline Sonork: 100.1575042
replace or change duplixer switch.
Sorry gsmlord ! You solution not work for me
or menu
hi.......
may be you can try call out ,phone can not call out i seen problem menu is wrong , you can go to menu service [call option- out to... you select to deactive] |
To Own !
Thank you Own !
I always previously than do with Alcatel OT302 - do set factory , reset ###337*07# !! But I have forgotten to say in past message that after change duplexer - a telephone has done one outgoing call , and once again ceased to work! |
@own
@Own
My friend, VED says: he reflashed phone, used LOTTO and Vygis with no results, so how u think it's menu wrong.....?
To ARC !!
Thanks ARC !
Possible I this did not much attentively! I presently will else try reflash and repaire , use secret zone changer ! |
No Try No Success!
or No Pain No Gain!
![]() ![]() ![]() ![]() Join Date: Oct 2001
Member: 6744 Status: Offline Thanks: 0
Hmmmmz
Pa gives signal ( U can measure TX power ) ? Maybe it very low ?
For me was PA ..... and simptom's as you said . Changed PA and all OK . |
Member: 5850 Status: Offline Thanks: 0
Try at first to check the power from PA, using smth like "flash antenna".
1. If there are sometimes a little power, then you need to rehot or resolder CPU or DSP (to the up of flash). 2. if you has always a little power, then you need to replace diplexer. 3. If there is no power, then you need to replace PA (very often) or rehot CPU, too that's all
