Old 09-11-2007, 11:04   #1 (permalink)
Member: 42604
Thanks Meter: 187
>> W370 Tracfone Unlock <<
Here's the procedure to unlock your Motorola W370 Tracfone. No convertion needed..
First flash your W370 with W375 firmware, i choosed
w375_0.0.80_Main_H80S_K2_1175254689.34M.bin = MAIN
w375_0.0.80_LP_A06_Cn.34P.bin = Language Pack
W375_Flex_A4_002_retail.34F.bin = FLEX
Flashing logs:
COM3 [VCP0] selected
"smart write" active
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Device: W375
Checking data, wait...
Connect...
Press and HOLD Power button...
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 6.9.75
HW version: MOTOROLA_H80S
LP ver:
Flex ver: FLEX_A0_00I
cpu id: 08B6
imei eeprom: 35451301280133
required SW version: 6.9.75
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_35451301280133_20070911-172858.34E.bin
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Language Pack
Writing: Flex
Write Done
Finished, time used: 592 sec
Remove/Install battery now !
After flashing I got my PHONE HACK ERROR, don't panic just unlock it..i used DIRECT UNLOCK..
Unlocking Logs:
Action: unlock
Device: W375
Connect...
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.0.80
LP ver: 0080_A06
Flex ver: FLEX_A4_002
cpu id: 08B6
required SW version: 0.0.80
user confirmed unlock for non-locked phone
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_35451301280133_20070911-174051.34E.bin
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
unlock step-5 Ok
finished Ok
Finished, time used: 30 sec
Hope this help in some other way...
WBR
RBT
The Following 29 Users Say Thank You to kasamiko For This Useful Post:
Old 09-11-2007, 11:06   #2 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
nice reference sir
br
The Following User Says Thank You to raezak For This Useful Post:
Old 09-11-2007, 14:57   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@kasamiko
Thank you very much for detailed test report !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-11-2007, 15:06   #4 (permalink)
Member: 166665
Thanks Meter: 35
thank's bro for test
dr hema
The Following User Says Thank You to dr hema For This Useful Post:
Old 09-11-2007, 15:08   #5 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
nice reference for infinity users..thanks RBT
The Following User Says Thank You to tolski For This Useful Post:
Old 09-19-2007, 07:38   #6 (permalink)
clearcom's Avatar
Member: 120669
Thanks Meter: 15
Nice One Bro.........
The Following User Says Thank You to clearcom For This Useful Post:
Old 09-19-2007, 08:53   #7 (permalink)
BCcommunication's Avatar
Member: 76456
Sonork: 100.1678368
Thanks Meter: 60
if u want direct unlock use Furious Gold 100000% tested unlock
The Following User Says Thank You to BCcommunication For This Useful Post:
Old 09-24-2007, 21:06   #8 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
direct unlock or not, the w370 tracfone must be flashed to be used with other network provider.
The Following 2 Users Say Thank You to mrfixit For This Useful Post:
Old 09-24-2007, 21:25   #9 (permalink)
naderhacker's Avatar
Member: 4365
Thanks Meter: 39
thx for info sir
all the best
The Following User Says Thank You to naderhacker For This Useful Post:
Old 09-25-2007, 04:19   #10 (permalink)
Member: 42604
Thanks Meter: 187
But this is NOT a Furious Gold section...
The Following 2 Users Say Thank You to kasamiko For This Useful Post:
Old 09-25-2007, 05:43   #11 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
@kasamiko
thnx to u , ur proced work 100% ,,
i tested today and 1800Mhz band works ok
really u do good job ,,,,
Amit Tank
The Following User Says Thank You to Amit Tank For This Useful Post:
Old 09-25-2007, 11:36   #12 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
Tested & Workin................. Thanks for sharing
The Following User Says Thank You to PhoneCareCenter For This Useful Post:
Old 09-25-2007, 12:57   #13 (permalink)
Member: 546351
Thanks Meter: 4
how to unlock mottorola w375 orange
The Following User Says Thank You to francis gabriel For This Useful Post:
Old 09-25-2007, 14:01   #14 (permalink)
Member: 124680
Thanks Meter: 2
Thanks Kasamiko for ur reseach it has help me to unlock one w370 successfully cuz i tried it before but had the hack 68 and there was not direct unlock at that time, keep on the good work bro.
The Following User Says Thank You to Kwame_11 For This Useful Post:
Old 09-25-2007, 16:58   #15 (permalink)
maka_gsm's Avatar
Member: 309772
Thanks Meter: 31
thank for this tutorial and which file did you use
The Following User Says Thank You to maka_gsm For This Useful Post:
W370 Tracfone Unlock / Flash bigmac1204 Scout 9 07-14-2010 07:47
>> T349 successfully unlock << jhepoy_org UST Pro II 7 09-02-2009 08:14
W370 tracfone unlock succes using smart-clip maxieboy Smart-Clip 10 09-05-2008 07:10
W370 TracFone Unlock Success Orange_Dominica Smart-Clip 12 08-12-2008 12:34
problem unlocking w370 tracfone wakuwaku Smart-Clip 7 08-04-2008 10:06
Page generated in 0.20537 seconds with 10 queries
