Old 06-03-2002, 18:27   #1
D-Brain
D-Brain's Avatar
Member: 7301
ALCATEL BE4 v.139 sim fault!
Hi All !
Alcatel 303 v. 139 refuse simcard after some seconds.
I turn it on , it serach the network, I can see that it can read the simcard because I can see the names in the sim phonebook, but after some seconds it says: "Verify Sim Card"
Already tryed unlocking and resoldering CPU and Texas DSP, but doesn't help.
Any idea???
Old 06-04-2002, 05:04   #2
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Software PRoblem
Hi
u have 100% faulty software:
check IMEI with back of your phone,
if not same, then it reflashed with wrong flash version.......
Try to repair by vygis or LOTTO
GoodLuck!
Old 06-04-2002, 18:37   #3
D-Brain
D-Brain's Avatar
Member: 7301
Hi Arc!
Thanks for you reply!
But I have already tryed LOTO Repairer by Vygis 1.2 , and it doesn't work with my phone
The stastus bar goes to 4% then it says "phone not connected" ...
Should it be v.139 software not supported?? What other progs shoul I try???
Old 06-04-2002, 19:07   #4
Chuk
Member: 7767
Hi D-Brain!
Try to downgrade it to v.135 with any be4 flasher and use LOTO Repairer by Vygis 1.2 again. Make backup before.
WBR
Old 06-04-2002, 19:15   #5
D-Brain
D-Brain's Avatar
Member: 7301
Ok, now "Loto Repairer" found the phone... It works with v.139 !
But, what .bin file should I send to the phone???
Are all good or what???
Old 06-04-2002, 19:37   #6
Chuk
Member: 7767
You need wirte files to phone, step by step, from first to last. After every writeing, You must power up phone with sim card and check for bugs (restarting). When phone begins work good, You must stop.
Old 06-04-2002, 22:42   #7
micmac
micmac's Avatar
Member: 10396
hi
i have the same pb in be5 124-02
any solution for repair this phone.
Old 06-05-2002, 18:42   #8
D-Brain
D-Brain's Avatar
Member: 7301
Hi All !
Thanks for Cuck and ARC , but the phone is still in fault
I've tryed partial flashes with Vygis and also a complete flash from another working phone, but the problem is the same.
Now I think it's an hardware fault... but I've already resoldered CPU !! What else should I try???
Old 06-05-2002, 20:03   #9
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
@D-Brain
please check your email
Old 06-06-2002, 09:45   #10
gsmsalers
Member: 11208
Hi.me too???
Hi.
Where can I find soft by Loto which you are talking about. For me never swa that? Does this soft can repair lost security partial without backup? Does this soft can repair not only be4 also be1 with 2mbyte flash?
Bye.
Page generated in 0.08833 seconds with 6 queries
