Old 09-20-2007, 16:44   #1
venuskarthick
venuskarthick's Avatar
Member: 233140
dear InfinitySupport finaly i got the pinout
dear InfinitySupport finaly i got the pinouthehe
1-ground,4-rx,11-tx but showing error on readflash plz see the log..
==== log opened: [9/20/2007 4:04:07 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe
Loading data, wait...
[Infinity Box] v1.49
S/N: 0997:010C
Wait...
Current device: Autodetect 6205-6227,6228 nor
Done
COM1 [Serial0] selected
error: can't open COM1
COM4 ready
COM4 [VCP0] selected
Device: Autodetect 6205-6227,6228 nor
Checking data, wait...
advanced flash detection active
Action: read NOR flash
Boot...
Press and HOLD Power button now !
baud autodetection active
19200
Connecting, wait...
Initializing[6219:8A01]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
detecting chip #00 in region #00...
flash: B000B101000000:B000B100000000
flash: Sharp Intel std [def 0008x002000 007Fx010000] 8Mb
detecting chip #01 in region #00...
flash: B000B004000000:B000B000000000
flash: Sharp Intel std [def 007Fx010000 0008x002000] 8Mb
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Check space...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detection phase #2...
detect device parameters finished
protocol ver: 01
ver. sw1: KCM_PCB01_GPRS_MT6219_EV.MAUI_05A_W05_36_MP_V10_F1.BIN
ver. sw2: MAUI.05A.W05.36.MP.V10.F1
ffs offset/size: 00EC0000/00140000
detecting eeprom area in 2 chip(s)...
checking area[00000000]: 00000000-007FFFFF...
checking area[00800000]: 00000000-007FFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 01
eeprom area: 00800000:00600000-007FFFFF
reading [flash[KCM_PCB01_GPRS_MT6219_EV.MAUI_05A_W05_36_MP_V10_F1.BIN]]...
warning: data size mismatch at 0x00EDA000, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
operation canceled by user
file saved: backup_flash[KCM_PCB01_GPRS_MT6219_EV.MAUI_05A_W05_36_MP_V10_F1.BIN]_20070920-163336.B0M.bin
Finished, time used: 1675 sec
Remove/Install battery now !
here is link for backup flash http://www.sendspace.com/file/9me800
see this & guid me how can i solv this problem...
Old 09-20-2007, 21:09   #2
InfinityHelp
Member: 148515
hello!
but what is a problem with your phone? Not powering on, hang or restart?
Old 09-21-2007, 10:45   #3
venuskarthick
Member: 233140
No sir there is no problem on this mobile it,s 100% working condetion mobile & it,s new mobile
i need flash file for this model
becoz i have same model 2 mobiles in dead Condetion
Old 09-21-2007, 18:04   #4
InfinityHelp
Member: 148515
hello!
read out flash from working set and send it to infinityhelp@yahoo.com.hk.
we will prepair files to rescue other dead phones
Old 09-21-2007, 18:12   #5
venuskarthick
Member: 233140
sir here i posted log is working set log only it,s the problem
when i try 2 read flash from new mobile it showing this error i tryed lot of time
but same result
Old 09-21-2007, 19:00   #6
adebam
Member: 180091
can you show us the the pinout correctly maybe others could successfuly read the flash and send it to support@infinity.
Adebam
Old 09-21-2007, 19:03   #7
adebam
Member: 180091
moreover which model of the phone are you trying
Old 09-22-2007, 13:32   #8
InfinityHelp
Member: 148515
hello venuskarthick!
what cable are you using? Via infinity box?
battery is ok? also try a lower speed
Old 09-22-2007, 17:26   #9
Santehnik
Member: 161985
I think it is no problem with a cable and with a phone.
Some time's Infinity can't repair this kind of phone (I don't know why). Because I had like this problems with few model of phone
warning: data size mismatch at 0x00EDA000, retry... and apiar a massage "retry or abort". By difirent box this phone is aliving. I'll send you a full information for this phone.
Old 09-22-2007, 18:55   #10
venuskarthick
Member: 233140
SIR now I Got it
today i tryed with v1.51 it,s readed full flash thanks for ur kindness
here is mobile info
MODEL: GM608
CPU NAME:MT6219A
Phone Bottom Connector Type: 2x6_mini(12 pin,s)
PHONE RX: 4th pin
PHONE TX: 11th pin
PHONE IMAGE:
FRONT & BACK CONNECTOR LOCATION
INFINITY FLASH BACKUP LOG
[Infinity Box] v1.51
S/N: 0997:010C
Wait...
Device: Autodetect 6205-6227,6228 NOR
Done
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
protocol ver: 01
eeprom chip: 01
file saved: backup_flash[KCM_PCB01_GPRS_MT6219_EV.MAUI_05A_W05_36_MP_V10_F1.BIN]_20070922-125655.B0M.bin
Finished, time used: 1730 sec
FLASH FILE BACKUP HERE http://www.sendspace.com/file/8zsmwg
Old 09-22-2007, 19:13   #11
venuskarthick
Member: 233140
ok now how can i rescue other dead phones???
Old 09-22-2007, 22:48   #12
InfinitySupport
Member: 130995
Flash phone with good flash file (f.e. your own backup from good phone) and then make "format ffs" if need.
Old 09-23-2007, 04:46   #13
dannyogolo
dannyogolo's Avatar
Member: 18200
Ok, IC.
@Infinitysupport,
I tot there should be something like ask/rpl ??
Also i suggest a sticked thread on simple tricks to repair major faults on these chinese phones.
Also what each button on the software can do. For instance whats NAND and CPU ? which do we format, etc. Things like this.
Today I successfully repaied a chinese phone by risking not to backup, bcos I was getting same error this guy got: mismatch, etc. I just decided to format without backup, and it worked.
Then again there is another chinese CPU model: 6226 - there are plenty here with this cpu. Are they supported ???
Old 09-23-2007, 09:21   #14
InfinitySupport
Member: 130995
Originally Posted by dannyogolo View Post
Ok, IC.
@Infinitysupport,
D:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm
D:\Program Files\InfinityBox\Documentation\Infinity-Box_ChineseMiracle_How_to_repair_reboot_with_sim.t xt
D:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_calculate_ChineseMiracle_Ask-Rpl.jpg
CPU: select according to phone hardware
ASK/RPL: software suggest you when it's need
Always make backup to avoid your lost time during searching backup files for your phone.
6226, 6227, 6228 CPU is supported.
Page generated in 0.10777 seconds with 6 queries
