![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
Member: 204045 Status: Offline Thanks: 21
N95i pinout
I need N95i pinout for 5x2 mini connector!
I try this one: Nokia-N95(T99) 2 sim connector_2x5_mini 1: +V 4: phone Rx (RJ45 pin 2) 5: phone Tx (RJ45 pin 3) 6: Gnd 10: connect to phone pin-1 This not work! BR |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 187451 Status: Offline Thanks: 7
@ .::KHURRAM::.
Thank you but what to check in Intinity manu: Autodetect 6205-6227,6228 NOR or Autodetect 6228 NAND? BR |
it can't be connected
i can't understand why..... BR |
Member: 130995 Status: Offline Thanks: 4,396
It's cable problem, wrong pinout. You must use correct cable and select correct COM port.
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http://forum.gsmhosting.com/vbb/showpo...36&postcount=7 |
all works OK!
Thank you! @.::KHURRAM::. it is correct pinout, thank you. BR |
