![]() ![]() ![]() Join Date: Jan 2005
Member: 106367 Status: Online Sonork: 1577436
How To Find Flash Proper From Suport For Cm
HERE I GOT N95 RH-19 CHINESE
HERE IS INFO READ BY INFINITY Code:
Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: T6226_05C_HW.1772.7670 Software version: MAUI.05C.W06.16.MP.V Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 33 sec Power off phone now ! NEED TO FLASH? THAN HOW TO FING PROPER FLASH FILE FROM SUPPORT |
@HERE LOG APPEAR WHILE READ EEPROM
![]() SO I GOT ANSWER THAT ON SUPPORT I CANT FIND FLASH FILE FOR THIS NEW VERSION SENDING THIS FILES TO SUPPORT EMAIL NEED TO ASK THAT CAN I MAKE FORMATT FFS [COMPLETE ] IS IT DANAGEROUS FOR PHONE I MEAN IF PHONE DEADS WATING |
![]() ![]() ![]() Join Date: Sep 2004
Member: 84268 Status: Offline Sonork: 100.114149
format FFS no dangerous for phone;
"ChineseMiracle": how to repair "reboot with SIM card" 1. make full flash backup for emergency case (use 921000 speed for fast operation) 2. select "safe format method" 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone powered-on if phone Ok go to step-6 if phone not Ok, go to step 2 and select "complete format method" 6. restore original imei |
@zino
same after ur trick 1=made ffs format [safe] and write imei [not ok] 2=made ffs formatt [complete] and write [not ok] phone is same after sim when calling to that no. phone restart thansk waiting |
Member: 130995 Status: Offline Thanks: 4,412
Did you tried to check phone hardware ? Are you sure that it's software problem ?
@infnity
its is boxed pack and also checked hardware its clean phones firmware detected by infinity exe ,so should i post this full flash to support mail waiting thanks |
@supporter
still waiting how to compete this phone after inseret sim and while calling its restart need help format ffs [safe] and [complete] no use same condition waitng thanks |
@support
can i use this flash file upload today on support Code:
CM_Nokia-N95_E553_XZY1ARTHRUTR_E553_GPRS_MT6226_S01.01_1_16 m_Ru_En_Th_Vn_Cn_Hi_Cn_Ar |
![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks: 332
hello!
i think you need to resolder flash IC |
Member: 4365 Status: Offline Thanks: 0
man check if the phone restart not turn off
some CM have defecive Pa |
@chiragp
you can try to use other firmware with version name like T6226_0... but I think that it's need to check RF part (I agree with Mr. naderhacker) |
#12 | ||
![]() ![]() ![]() Join Date: Dec 2005
Member: 210304 Status: Offline Sonork: 100.1573283
i have 5 pcs same problem
when i have flashed it with Quote:
and i am now trying with anther tool waiting any news about this problem...... |
hello mr. SiLver*GSM!
no need to flash your phone with alien firmware. first of all start from formating FFS (safe and complete) restore IMEI. check phone functionality |
