![]() ![]() ![]() ![]() ![]() Join Date: Apr 2007
Member: 480351 Status: Offline Thanks: 9
i have nokia n73, every i put simcard inside, phone not switch on.. but if no simcard inside... phone normal...
i want to ask, is my phone LOCKED or hardware problem ?, if yes how to solve my problem ?? which cable i must use ? thanks |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 289200 Status: Offline Sonork: 100.111845
phone not power with sim card or restart?
Member: 130995 Status: Offline Thanks: 4,412
Cable:
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http://forum.gsmhosting.com/vbb/showpo...36&postcount=7 "ChineseMiracle": how to repair "reboot with SIM card" 1. make full flash backup for emergency case (use 921000 speed for fast operation) 2. select "safe format method" 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone powered-on if phone Ok go to step-6 if phone not Ok, go to step 2 and select "complete format method" 6. restore original imei |
ohh.... okey, btw... how i can found chines mobiles files flash in infinity ??
@sammy75
go to support area -> "flashfiles" -> "Chinese Miracle" |
its not hardware probel... every i insert the sim card phone only show nokia and enter pin... ok i have enter pin and then phone not power on... if i not put the simcard...phone normal
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 187451 Status: Offline Thanks: 9
