![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 248050 Status: Offline Thanks: 7
CECT i658 (N72) Pinout?
I need pinout for CECT i658 (N72) it is diffrent than which already posted here is attach pic. and power switch is on top and pin 1 is gnd. it is urgent.
BR, Vicky |
Member: 130995 Status: Offline Thanks: 4,390
keyboard top
1.........12 1: Gnd 5: Tx 6: Rx |
this have 2x5 connector. i try with all pins and also try connector near sim jack but fail. plz give good working pinout.
BR, Vicky |
Dear Friend,
Please, check previous messages in this thread and for sure you will find an answer for your question. Of course, everybody so busy with writing so nobody have time for searching and reading, so I post detailed description here, probably after this my move you will start to respect other people and you will start to use "search" button. Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http://forum.gsmhosting.com/vbb/showpo...36&postcount=7 |
dear sir,
i have try to search this whole forum and found one i658 pinout by faisal computer also in ur pinouts but as u see attached pic that it is diffrent pcb and I already try all of ur steps and also try connect one by one but still not connect maybe cpu diffrent, problem is restart with sim. here is cpu detail skyworks CX80502-36 E715590.1 0509 MX ARM if this cpu detail is show u that is diffrent than let me know that it is supported or not at this time if not than i will return set to customer coz he is being angry and cannot understand our hard work. Waiting for your kind response. Kind regards, Vicky |
This cpu is not supported by "Chinese Miracle".
Hope you understand now. |
Member: 243866 Status: Offline Thanks: 1
ineed to pinouts for this model plz help me
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2003
Member: 28004 Status: Offline Thanks: 198
i have GSM FCT made in china , model = BKG-331T ...
i open the box , there i got some details .. i CPU is SKYWORKS CX80502-36 is this cpu supported . by infinity .. i want to unlock this set ... please help .. thanks |
![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks: 332
hello!
this MCU is not yet supported |
![]() ![]() ![]() ![]() Join Date: May 2005
Member: 142949 Status: Offline Thanks: 82
