![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
Member: 202611 Status: Offline Thanks: 46
COM1 [Serial0] selectedDevice: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC22E200000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [B 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: EC22E200000000:01AC0000000000 flash: Samsung AMD/Fujitsu std [B 0008x002000 007Fx010000] 8Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC22E200000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [B 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: EC22E200000000:01AC0000000000 flash: Samsung AMD/Fujitsu std [B 0008x002000 007Fx010000] 8Mb number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.83279E01.[M500TV_S103_PCB01_GPRS_MT6226_S01.00_0.BIN_C6D5EAA 2].rpl New firmware detected: M500TV_S103_PCB01_GPRS_MT6226_S01.00_0.BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished device-id: 83279E01 protocol ver: 04 ver. sw1: M500TV_S103_PCB01_GPRS_MT6226_S01.00_0.BIN ver. sw2: M500TV_S103.00.0 ffs offset/size: 00800000/00200000 detecting eeprom area in 2 chip(s)... flash: EC22E200000000:29EA0000000000 checking area[00000000]: 00000000-007FFFFF... flash: EC22E200000000:01AC0000000000 checking area[00800000]: 00000000-007FFFFF... eeprom found near: 00800000 Detected eeprom address is non-standard: 00800000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom address[00800000] confirmed by user detecting eeprom size... eeprom size: 00800000 eeprom chip: 01 eeprom area: 00800000:00000000-007FFFFF reading [eeprom[M500TV_S103_PCB01_GPRS_MT6226_S01.00_0.BIN]]... warning: data size mismatch at 0x00888400, retry... read error recovered warning: data size mismatch at 0x00A15400, retry... read error recovered file saved: backup_eeprom[M500TV_S103_PCB01_GPRS_MT6226_S01.00_0.BIN]_20070924-181132.B0E.bin flash: EC22E200000000:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: EC22E200000000:01AC0000000000 Write Done file saved: backup_system_log_83279E01_M500TV_S103_PCB01_GPRS_ MT6226_S01.00_0.BIN_C6D5EAA2_20070924-181235.B0X.bin Finished, time used: 895 sec Remove/Install battery now ! i was formatting ffs on this unit it give me this error and phone cant power on i flash eeprom phone come alive but in same condition that when i select tones phone reboot itself and i cant send msg only i can recieve
![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks: 332
hello!
try to format FFS one more time, if will not help- reball and resolder flash IC. |
Member: 130995 Status: Offline Thanks: 4,387
@stivubicco
Also try to make this: select "safe format" method and make Format FFS in "safe" mode. Also, please, send your backup_system_log_83279E01_M500TV_S103_PCB01_GPRS_ MT6226_S01.00_0.BIN_C6D5EAA2_20070924-181235.B0X.bin file and flash backup file to InfinityBoxSupport@gmail.com for future research. Thank you ! |
thanx for rply and i will test and send replay coz i just receive one today with same model and give same error while formatting
Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E553_Y1THAIRUARFRBT.01.1_26S01 Version: M500Z_05C_HW warning: wrong packet checksum warning: wrong packet checksum warning: wrong packet checksum 199 of 211 items cleared 5 items remains Finished, time used: 53 sec Remove/Install battery now ! thanx ifinity team i flash eeprom from backup and phone come alive and i format ffs again in safe mode and phone was repaired and work. my simple qestion to infinty support is this safe mode is more gud than compelete mode coz this compelete take much time than safe mode and does safe mode make backup. thanx in advance |
"Safe" mode can be useful in situations when software in "complete" mode can't detect eeprom address correctly.
Backup: better make backup in any case what is better: better is mode that gives you good results. It depends on phone. F.e. in some cases (eeprom very serious damaged) it's impossible to make "safe" format and only "complete" is possible. |
#7 | |
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005
Member: 103945 Status: Offline Sonork: 100.112828
i have same problem i would tomorrow try to flash eeprom backup and then formaat in save mode i hope to alive my phone
