Old 09-25-2007, 07:51   #1
zipzap_kill
zipzap_kill's Avatar
Member: 136173
Sonork: 1581759:111
problem
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
Press and HOLD Power button now !
baud autodetection active
19200
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 24 sec
Remove/Install battery now !
team here is my log model no is 830 cpo 6227 cannot connect please upload usb drivers thanks
Old 09-25-2007, 08:16   #2
zahid_gsm
Member: 232607
Sonork: zahidgsm
i m also facing that prob but but when i restart my pc then all come ok plz try it again and check batt ok
Old 09-25-2007, 18:30   #3
InfinitySupport
Member: 130995
Action: reset
Boot...
19200
Connecting, wait...
Boot Fail
It's cable problem, wrong pinout. You must use correct cable and select correct COM port.
bottom connectors and different pinouts we recommend you to make detailed description of model,
attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector.
After you have this information prepared, please, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt
if not helps, please read: http://forum.gsmhosting.com/vbb/showpo...36&postcount=7
Page generated in 0.06566 seconds with 6 queries
