![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 115516 Status: Offline Thanks: 281
help help CECT K89
Hi members
i have CECT K89 software problem handset i flash the phone after flash set is dead from diff firmware CM_Cect-K89_L555501.5.3.1.0T03S0427_M451A_L555501.1.0_M451 ATHL_M200_01_M6_05A_HW_2006-04-27_8m_En_Fr.B0M.bin CM_Cect-K89_L557703.5.3.1.0T01M0221_M451A_L557703.1.0_M451 AXSK_M200_03_M6_05A_HW_2006-02-21_16m_En_Cn.B0M.bin CM_Cect-K89_L557710.5.3.1.0T01S1225_M451A_T557710.1.0_M451 A_XSK_M200_10_M6_05A_HW_2006-12-25_8m_En_Th_Cn.B0M.bin COM3 selected Device: Autodetect Checking data, wait... advanced flash detection active Action: Flash write "smart write" active Write: Firmware Skip: Customization Skip: Language Pack Write: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02]... Release Power button now ! Boot Done Initialize... detecting chip[00] in region[00]... flash: 01227E22212200 flash: 29EA0000000000 flash: AMD/Fujitsu std [0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... operation mode: Fast detection mode device parameters autodetection in progress.. detecting chip[00] in region[00]... flash: 01227E22212200 flash: 29EA0000000000 flash: AMD/Fujitsu std [0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: 01227E22212200 flash: 29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: device identification detection failed, no any information found. possible reasons: . old firmware type w/o identification data . wrong firmware . damaged firmware flash: 01227E22212200 flash: 29EA0000000000 reading [eeprom]... file saved: backup_eeprom_20070925-130306.B0E.bin Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: 01227E22212200 flash: 29EA0000000000 Write: Firmware Area: Eeprom flash: 01227E22212200 flash: 29EA0000000000 Write: Eeprom Write Done Finished, time used: 472 sec Remove/Install battery now ! i need exact firmware & eprom files to alive the set please help help thanks in advance |
![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks: 334
hello!
so what was original phone firmware version? |
k89
backup_system_log_0BD51E29_[KP26_06B_PCB01_GPRS_MT6226_S01.P03_SC_SAM_NC0_1_0_ 5TB1C2_26B.BIN]_FE505B3C_20070925-124034.B0X.bin
Member: 130995 Status: Offline Thanks: 4,431
1. send backup_system_log_0BD51E29_[KP26_06B_PCB01_GPRS_MT6226_S01.P03_SC_SAM_NC0_1_0_ 5TB1C2_26B.BIN]_FE505B3C_20070925-124034.B0X.bin file to InfinityHelp@yahoo.com.hk 2. try to flash your phone with this file (and make ask/rpl): CM_Nokia-N95i-slider_KP26_06B_PCB01_GPRS_MT6226_S01.S03_M4_SAM_N C0_2_2_8TB2C4_26B_16m_En_Fr_Ru_Ar.B0M.bin |
